Old 04-16-2026, 12:35 AM   #1
Blownflatheaddeuce
Blownflatheaddeuce's Avatar
Default Engine sleeve source...
Hey guys, I'm needing to source a sleeve for an 8BA that's at 3 5/16" +.030 or 3.342" as I can't source one locally.
What's the best source, I have all the necessary dimensions.
Thanks !
BFD
Blownflatheaddeuce is offline   Reply With Quote
Old 04-16-2026, 03:25 AM   #2
Mart
Mart's Avatar
Default Re: Engine sleeve source...
I've bought sleeves from Rockauto before now. There are 2 thicknesses, the thicker one would take a + 30 bore. The thinner one might too.
Mart.
Old 04-16-2026, 10:08 PM   #3
Ronnieroadster
Ronnieroadster's Avatar
When I need engine sleeves I always use LA sleeve.
Ronnieroadster
I use the F word a lot no not that word these words Flathead, Focus and Finish
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block
First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921
First Ford flathead roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH reset the record in 2024 to 211.830 running to mile four. Top speed 2024 mile five 220.672 exit speed 221.587
Ronnieroadster is offline   Reply With Quote
Old 04-16-2026, 10:27 PM   #4
deuce_roadster
deuce_roadster's Avatar
I have NOS 11-a sleeves that seem to be the "thick" ones. Have no way to measure them.
