Old 04-15-2026, 05:28 PM   #1
34fordy
34fordy's Avatar
Default V8 length
Are the lengths from the front of a bare block to the back of the bell housing of 32-48 engines the same as a 49-53 block with the bell housing attached? I have not been able to find the measurements. Thanks in advance.
34fordy is offline   Reply With Quote
Old 04-15-2026, 06:02 PM   #2
big deuce
big deuce's Avatar
Default Re: V8 length
Yes, '41 block is 25 5/8". 8ba block is 22 5/8 + 3 bell = 25 5/8
big deuce is offline   Reply With Quote
Old 04-15-2026, 08:19 PM   #3
34fordy
34fordy's Avatar
Thanx, I believe that my 37 21 stud is the same.
Old 04-18-2026, 11:26 AM   #4
51shoeboxer
An interesting observation from my youth. Aftermarket companies, such as J.C. Whitney, used to sell adapters that would allow you to use a later flathead (which didn't have the rear extension on the block) with an early transmission. I learned pretty quickly it was much cheaper to go to a junkyard and get the factory extension that Ford put on later flatheads.
51shoeboxer is offline   Reply With Quote
Old 04-18-2026, 11:52 AM   #5
tubman
tubman's Avatar
Really? I have never seen a commercial late flathead to early flathead adapter. Do you know who made one?
Old 04-18-2026, 04:14 PM   #6
51shoeboxer
There are several on ebay now.
Old 04-18-2026, 09:08 PM   #7
tubman
tubman's Avatar
Got an auction number? What brand are they?
Old 04-19-2026, 10:11 AM   #8
51shoeboxer
Here are several on ebay. I don't know the manufacturer(s)
147097442810
227287591374
277880921541
267325273514
Old 04-19-2026, 12:06 PM   #9
tubman
tubman's Avatar
In the interests of all concerned, I'm dropping this.
Old 04-19-2026, 09:04 PM   #10
big deuce
big deuce's Avatar
51, those adapters on ebay ARE Ford, not aftermarket. Same ones you were seeing in the junkyards... I have never seen an aftermarket adapter either unless it was for joining chevy/Ford, chrysler/Ford etc.
Old 04-20-2026, 06:34 PM   #11
51shoeboxer
At this late date, I am unable to prove that there were aftermarket adapters, but I'm pretty sure that J.C Whitney, Warsharsky, and Honest Charley sold late Ford flathead to early ford transmission adapters.
Old 04-20-2026, 06:49 PM   #12
tubman
tubman's Avatar
Speedway Motors used to sell them and had them in their catalog. They were actually a sand-blasted Merc bell housing with a "Speedway" tag. Interestingly, they came without the starter plate, which made them useless. I think they were $55. I'll bet that you saw something similar.
Old 04-22-2026, 03:50 PM   #13
rotorwrench
rotorwrench's Avatar
The 37 and later pumps can be used on the 8BA block, but the cam and front distributor usually go with it plus the Mercury pan to get a good fit. The earlier cars with the different front mounts can use adapters. I think the most common mount adapter is reproduced for that purpose.
