Old 04-09-2026, 04:21 PM   #1
Bruce_MO
Default 1917 touring- door skin removal
What’s the easiest way to remove the skins from the wood door frames on a touring? I see they’re nailed on with lots of small nails. Grind the heads off, or get under the tabs on the skins and pry? I may reuse the wooden inner frames on two of the doors, as they’re in excellent shape. I need to remove the skins to get at the back sides with dollies and other body tools, as the doors are all very wavy and beat up. Thanks
Bruce_MO is offline   Reply With Quote
