Old 04-06-2026, 08:57 AM   #1
blownford
Default '36-'39 Shift Lever
I had the shift tower off the '39 trans in my car and I found the stud and ball on the end of the shift lever had some significant wear. The only replacement lever I could find was on ebay and no guaranty it was in better condition than the one I had. I understand you can weld it up and file it into shape but I found a better solution.
Third Gen offers a new lower section of the shift lever, 91A-7210, $58. It has a 3/8 diameter stub to connect to a Gennie Shift lever. I had to bend it to the proper shape for my application. The Gennie levers come with 2 set screw to hold it to the stub.
I ordered a lever and after installing it, I found the set screws were not sufficent to prevent it from rotating on the stub, so I pinned it and that solved the issue.
It worked great, so I cut the end off of the old lever and drilled it for the 3/8 stub and two roll pins. I have a spare now.
blownford is offline   Reply With Quote
Old 04-06-2026, 05:28 PM   #2
35fordtn
35fordtn's Avatar
Default Re: '36-'39 Shit Lever
I try to use every product we sell, and this is one I have yet to personally use. Good to hear real world experience.
35fordtn is offline   Reply With Quote
Old 04-06-2026, 06:42 PM   #3
ford38v8
ford38v8's Avatar
Just going by the title, I've got one of those levers (in white porcelain) on my toilet.
Alan
Old 04-06-2026, 07:49 PM   #4
hueyhoolihan
now that's what I call a Freudian slip!
hueyhoolihan is offline   Reply With Quote
