Old 04-04-2026, 01:42 PM   #1
rfitzpatrick
Default This Is Embarrassing
Changed out my Fan Belt and now the radiator temps never rise above 160 degrees -- even in Florida weather.
rfitzpatrick is offline   Reply With Quote
Old 04-04-2026, 02:26 PM   #2
nkaminar
nkaminar's Avatar
Default Re: This Is Embarrassing
Something wrong with your thermometer?
Old 04-04-2026, 02:56 PM   #3
JayJay
Sounds like maybe your old belt was slipping. Good enough reason to replace it.
JayJay
San Francisco Bay Area
1930 Murray Town Sedan (under reconstruction)
1931 Briggs S/W Town Sedan
It isn't a defect, it's a feature!
JayJay is offline   Reply With Quote
Old 04-05-2026, 11:09 AM   #4
katy
katy's Avatar
Install a 180° thermostat!
Old 04-07-2026, 07:42 AM   #5
Mitch
I would think most people would be happy with that problem.
Mitch is offline   Reply With Quote
Old 04-07-2026, 11:08 AM   #6
Ruth
I don't like for my engines to run that cool.
Ruth
Old 04-07-2026, 01:29 PM   #7
JayJay
I’d be delighted to have that issue. I’ve been pulling my hair out trying to figure out where my chronic overheating is coming from.
JayJay
Old 04-07-2026, 05:56 PM   #8
The Master Cylinder
The Master Cylinder's Avatar
I agree, You need to run your engine hot enough to boil off condensation and unburned fuel byproducts that naturally accumulate within the crankcase. If the oil does not reach a high enough temperature, these contaminants remain suspended, leading to sludge formation and accelerated engine wear.
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is offline   Reply With Quote
Old 04-08-2026, 06:36 AM   #9
nkaminar
nkaminar's Avatar
Causes of overheating:
  1. Bad radiator
  2. Loose or worn out fan belt
  3. Too retarded or too advanced timing
  4. Too lean fuel/air ratio
  5. Clogged radiator and/or engine
  6. Rust, scale, sludge coating engine cooling cavities
  7. Bad thermostat (enlarge holes in flange)
  8. Bad water pump (highly unlikely)
