Old 04-03-2026, 10:01 AM   #1
rottenron36
rottenron36's Avatar
Default 36 pickup head lights quit working!
My 36 pickup head lights and tail lights, quit working over the winter rest. They have been working fine for 5 years. Stock switch at the steering box, 6 volt posi tive,new wiring harness when restored. I need to know where to start, testing things. I hoping to not take the switch apart as it is a bear to work on. Power at the fuse, under the dash. Thanks for looking, and any advice. Ron
rottenron36 is offline   Reply With Quote
Old 04-03-2026, 10:22 AM   #2
glennpm
glennpm's Avatar
Default Re: 36 pickup head lights quit working!
Without taking the bail for the switch off, twist it back and forth a little while pushing it towards the steering wheel. Push with force the wire bundle exiting the switch also toward the wheel.
Archives of historical but relevant older articles:
Hover mouse over the links below and click!
Rumble Seat’s Notes
Techno Source for the 1932 thru 1953 Flathead Ford
Old 04-03-2026, 12:08 PM   #3
rottenron36
Thanks glennpm, I will start there, and thanks for your reply. Ron
Old 04-03-2026, 06:27 PM   #4
hueyhoolihan
i usually get out my 6v or 12v (whichever applies) small battery, my small test wires and start working backwards from the bulbs.
hueyhoolihan is offline   Reply With Quote
Old 04-04-2026, 07:55 PM   #5
ford38v8
ford38v8's Avatar
You should always have power "at the fuse". What you need is power at both ends of the fuse.
Alan
