Old 04-02-2026, 01:01 PM   #1
leon bee
Default Calming Down a 6v Starter on 12v?
I got nothing against 6 volts, I like it. But I have one little yard truck with a big 12v winch on a boom out back. So I put an alternator on the 8BA. Man, the starter really hits hard. This is a seldom used truck.
I was thinking: We always hear about using big fat wires on 6v, which I do. What if I used a long, skinny lead down to the starter. Shouldn't that weaken the starter? Harm anything? I guess under voltage might not be good for the motor.
leon bee is offline   Reply With Quote
Old 04-02-2026, 02:15 PM   #2
Bob C
Default Re: Calming Down a 6v Starter on 12v?
I've heard of installing a starter Bendix spring on the starter cable stud and then the cable to the spring.
Old 04-02-2026, 05:43 PM   #3
mcgarrett
I did this to a Model T starter on 12 volt and it seemed to work fine. I think that it did slow it down some and didn't behave like it was attempting to wreck the bendix either.
mcgarrett is offline   Reply With Quote
Old 04-02-2026, 08:27 PM   #4
hueyhoolihan
my major concern would be the possibility of a very hot battery wire.
hueyhoolihan is online now   Reply With Quote
Old 04-02-2026, 09:07 PM   #5
oldbugger
oldbugger's Avatar
I've had my 35 on 12v for 8 yrs with 6v starter with no problems, knock on wood. Starts then slows down to an idle haha
oldbugger is offline   Reply With Quote
Old 04-03-2026, 05:33 AM   #6
flathead48
I always used 12 volt coils with a third shunt coil, starters will work like 12 volt but no slamming when engaged. Saves bendix & ring gear
flathead48 is offline   Reply With Quote
Old 04-03-2026, 06:51 AM   #7
Tim Ayers
I believe I bought one of your starters from you on the HAMB. Plan on installing it shortly.
Old 04-03-2026, 07:40 AM   #8
kurt v
flathead48, are you saying that starter acts like 12 volt but is being turned over by 6 volt battery ?
kurt v is offline   Reply With Quote
Old 04-03-2026, 10:48 AM   #9
flathead48
No sir, it is for 12 volt conversations with basically a 6 volt starter, the 12 volt coils are the easiest fix & work very smooth.
Old 04-03-2026, 10:50 AM   #10
flathead48
Tim, any problems let know, even I am retired I stand behind my work. Thanks, Rick
Old 04-03-2026, 11:05 AM   #11
petehoovie
petehoovie's Avatar
Old 04-03-2026, 11:37 AM   #12
Bored&Stroked
Bored&Stroked's Avatar
Listen to Flathead48 and have him convert your starter over (if he has time). He knows his stuff and does great work!
Old 04-03-2026, 04:01 PM   #13
flathead48
Thanks B&S for the kind words
Old 04-04-2026, 11:12 AM   #14
leon bee
I had thought of that last year. Just missed a nice converted generator on eBay. And I'd gotten the impression flathead48 was trying to enjoy retirement..........something like that.
Old 04-04-2026, 09:06 PM   #15
Gene1949
Gene1949's Avatar
https://www.fordbarn.com/forum/showt...rt+starter+12v
Been discussed here many times. I bought a rebuilt Y block starter from NAPA. Used the 8BA armature, end plate and bendix. Used the Y block case w/the 12 volt field coils AND the endplate with the new brushes.
No special tools and took about a 1/2hr
Gene1949 is offline   Reply With Quote
Old 04-05-2026, 07:29 AM   #16
Y-Blockhead
Y-Blockhead's Avatar
Maybe I should butt out as I am a Model A guy, for our starters the vendors sell 12 volt field coils. Maybe something similar is available for V-8s.
Old 04-05-2026, 06:39 PM   #17
Hitman
Get those while you can, they don’t make the new 12v coils used in the A starter conversions.
Hitman is offline   Reply With Quote
Old 04-06-2026, 06:52 AM   #18
ssffnomad
ssffnomad's Avatar
Quite some time back, flathead48, converted our Starter to 12V. Now engages nice and smooth without any slamming. We are close by to each other. Great folks they are.
Stretch
ssffnomad is offline   Reply With Quote
Old 04-06-2026, 07:58 AM   #19
Tim Ayers
Will do, Rick. Thank you! I'll also report back on how it works vs. a straight 12V starter.
Old 04-06-2026, 09:27 AM   #20
Robert/Texas
Robert/Texas's Avatar
About 15 years ago the starter on my '34 roadster went out. I gave the starter to a member of our club who specialized in generator and starter repairs. He said that it needed a part which he didn't have and that it would take a while to get it fixed. After a few weeks I got tired of waiting so I ordered a Stump-Puller starter from one of the vendors. I received this starter on the same day as I received my old starter back but decided to install the Stump-Puller on the car. I’ll never go back. This starter is so quiet that I can hardly hear it and when I touch the starter button that I have on the dash the engine starts silently and immediately. I met 3 Model A guys a few weeks ago and they were amazed how quiet it was.
Robert/Texas is offline   Reply With Quote
