Old 03-29-2026, 03:39 PM   #1
jack99
Default 1940 flat head with a crab dist.
Question, Should I have spark on the coil wire after it is pulled from distributer?
Thanks.
jack99 is offline   Reply With Quote
Old 03-29-2026, 05:30 PM   #2
Sid
Sid's Avatar
Default Re: 1940 flat head with a crab dist.
If I understand you correctly. There will be a spark from the coil wire every time the points break.
Sid is offline   Reply With Quote
Old 03-29-2026, 05:32 PM   #3
hueyhoolihan
if you have a canister style coil and the coil wire is pulled OUT OF THE CANISTER, AND THE IGNITION IS ON and even if the engine is NOT running there will be no spark from the coil wire. however, if under the same circumstances, and the coil wire has been pulled OUT OF THE DISTRIBUTOR CAP, there will be quite a jolt emitted from the end of the coil wire every time the points are opened. and that can easily be accomplished on most distributors. IOW, the engine need not be running, nor the engine turning over at all under some combination of circumstances to get a spark from the end of a coil wire plugged into a canister coil if the ignition has been turned on.
hueyhoolihan is offline   Reply With Quote
Old 03-30-2026, 06:51 AM   #4
Terry,OH
Terry,OH's Avatar
Yes. with all the other wires attached. Take the coil wire close to a ground and rest it there.
