Old 03-25-2026, 11:00 PM   #1
SkylarknMerc
Default 59A/B intake Pcv valve conversion
Hey guys, I'm looking for info on a pcv valve conversion for a 59A/B intake.
I tried to do a search but came up empty.
I have a 255 8CM Mercury, and currently running the PCV valve where the old down draft was before.
Earlier this year I came across a deal I couldn't pass up on, a pair of Offenhauser #400 heads and a 4 barrel Holley 390 cfm and Offenhauser intake to match.
Doing some research I found out both heads and intake will fit on my 8CM, the heads I have to plug a hole on the block (?) And the intake will fit too, but won't have the downdraft tube hole , and the oil fill tube in the intake manifold that came on the 8CM motor.
Since I'll be running an electric fuel pump, the original mechanical fuel pump mount will be blocked off. I was thinking of installing the PCV valve on the blank plate by drilling a hole in it for the valve.
Has anyone done that or will this not work out?
Thank you in advance for taking the time.
SkylarknMerc is offline   Reply With Quote
Old 03-25-2026, 11:21 PM   #2
tubman
tubman's Avatar
Default Re: 59A/B intake Pcv valve conversion
It is a known fact that the crankcase ventilation is totally different between the later 8BA type flatheads and their earlier brethren. Here are a couple of diagrams showing each type. Keep these in mind when considering this project.
I believe a couple of guys on here have done it by mounting the PCV valve in the valley under the intake and running some plumbing. I have no idea how effective it is.
Old 03-25-2026, 11:51 PM   #3
Newc
Newc's Avatar
Problem is with a 59 A/B type-oil pan breather. . I weld that closed and with a pipe coupling there use that for the PVC source. Newc
Old 03-26-2026, 03:12 AM   #4
SkylarknMerc
Thank you for the response
Looking at the first illustration, won't the direction of the TEAL arrows go the opposite way, as the Vacuum at the carburetor base be going In/Down the intake into the cylinders?
Old 03-26-2026, 09:04 AM   #5
glennpm
glennpm's Avatar
THIS WILL WORK ONLY ON THE 59AB BLOCKS.
For an 8BA, 1949-1953, tap into the "road draft tube"
I have a PCV on my 268CI 59A. I used a MOPAR valve that I found referenced in an old article which used a MOPAR PCV. I also add a piece of open cell foam into the oil pan vent.
Archives of historical but relevant older articles:
Hover mouse over the links below and click!
Rumble Seat’s Notes
Techno Source for the 1932 thru 1953 Flathead Ford
glennpm is online now   Reply With Quote
Old 03-26-2026, 09:39 AM   #6
petehoovie
petehoovie's Avatar
Old 03-26-2026, 02:40 PM   #7
SkylarknMerc
Thank you for your input!
I guess I could follow the first steps, drilling and installing the PCV valve up front, and connecting it the carburetor base where there is currently a vacuum connection.
Old 03-26-2026, 02:52 PM   #8
petehoovie
petehoovie's Avatar
Old 03-26-2026, 02:52 PM   #9
glennpm
glennpm's Avatar
Yes, that's correct.
Regarding the PCV valve, the one I used, referenced in the article is for a 3L or 183CI engine.; 1/8" MNPT X 5/16" hose barb. It works great for me with no excess oil film on the firewall or oil pan.
There is another PCV that also works in the horizontal position that is a little larger and made for SBC among others, in the 300CI range.; NAPA 2-9255 AND Standard SIV100. These have a 1/4 MNPT X 1/2" hose barb. Note the flow direction. These two flow toward the threaded end. The MOPAR flows toward the hose barb end of the PCV.
Rumble Seat’s Notes
Old 03-26-2026, 04:09 PM   #10
SkylarknMerc
Kool! Thank you.
Old 03-26-2026, 05:31 PM   #11
rich b
rich b's Avatar
Looks like that intake could be an 8BA intake by drilling the road draft tube boss to mount your PCV valve and boring the breather boss to fit your push-in tube & breather cap.
rich b is offline   Reply With Quote
Old 03-26-2026, 07:43 PM   #12
SkylarknMerc
I thought of that, just drilling a hole to put the PCV valve there only, and using the current oil fill tube in the back and leave the breather cap there and let it flow from back to front then vacuum in the manifold.
Old 03-27-2026, 01:59 PM   #13
Zeke3
Zeke3's Avatar
Attached is a link to a discussion on this topic that may help you from our late friend V8Coopman.
https://www.fordbarn.com/forum/showt...e+ventilationK
Zeke3 is offline   Reply With Quote
Old 03-27-2026, 03:52 PM   #14
rich b
rich b's Avatar
Looking at Tubman's picture of 8BA internal air flow it appears drawing air in thru a rear mounted breather may "short circuit" flow thru the lifter valley; whether that would amount to anything is anybody's guess.
Old 03-28-2026, 06:26 AM   #15
glennpm
glennpm's Avatar
The way "Mr 42" handled it was very good in my opinion. Regarding his design, I would do it a little differently with a 59A intake manifold on the 8BA. I would fix a short section on heater hose or similar, pushing the hose into the top of the block that the draft tube would slip into. Trim the hose such that it butts up against the bottom of the intake. Once trimmed, fix the hose in place. A hose clamp or a couple of zip ties just above the block to hose junction would work. You are just want to keep the hose from being pushed down further into the block. Tap the intake just above the this hose for hose connections for the suction side of the PCV. Connect the outlet of the PCV to manifold vacuum beneath the carb.
Note that the hose to block to underside of the manifold doesn't have to be super tight. The suction will be sufficient to draw from the crankcase and little to nothing from the fresh air inlet at the back of the 59A intake manifold.
https://www.fordbarn.com/forum/showp...38&postcount=6
Rumble Seat’s Notes
Old 03-28-2026, 07:42 AM   #16
glennpm
glennpm's Avatar
Deleted
