Old 03-25-2026, 03:12 PM   #1
marty in Ohio
marty in Ohio's Avatar
Default radiator sealer
I've noticed a small seepage at the bottom of my radiator. Last month I bought a product from Snyder's called a ceramic motor sealer. When I opened the bottle today I noticed sealer had separated and a thick layer of white "stuff" had hardened at the top. I tried to mix it and finally heated it to try to get to blend after talking to Snyder's. The white stuff had to be broken into smaller pieces. Now I'm not sure I want to dump this in my radiator. Has anybody used this stuff and what was your result?
Marty
marty in Ohio is offline   Reply With Quote
Old 03-25-2026, 06:07 PM   #2
cadillac512
cadillac512's Avatar
Default Re: radiator sealer
That container sure sounds like it has passed its "use by" date.
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'30 Model A Speedster
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 03-26-2026, 06:34 AM   #3
Ray64
Ray64's Avatar
I used a table spoon of black pepper,worked for me RAY
Ray64 is offline   Reply With Quote
Old 03-26-2026, 09:34 AM   #4
marty in Ohio
I think you're right Cadillac512. I was surprised when I called Snyder's and they said "strain it and stir it up." I don't think I'm going to pour that stuff in my radiator.
Ray64, I've heard of sawdust in the transmission, but I never heard of pepper in the radiator. I'm gonna give that a good think!
Marty
Old 03-26-2026, 10:29 AM   #5
Tacoma Bob
Tacoma Bob's Avatar
Sounds like Water Glass (sodium silicate) Throw it away. A well meaning club member dumped Water Glass in my radiator. What a mess. What hardened at the top of your container is what will happen in your radiator tubes.
Tacoma Bob is offline   Reply With Quote
Old 03-26-2026, 10:52 AM   #6
marty in Ohio
Thank you all for your responses. I'm learning! I've owned this car for 34 years and never had any problems with the radiator. It's been boiled out a couple times, but now it doesn't seem to be a good radiator shop in north east Ohio.
Marty
Old 03-26-2026, 02:06 PM   #7
Werner
Werner's Avatar
Guten Abend Marty.
Couldn't you solder it yourself? The cooler material is well-suited for that. Use leaded solder containing flux, and a soldering iron with >300-500 W.
Those cooler sealants rarely help and often cause blockages, etc.
Beste Gruesse aus Deutschland,
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 03-26-2026, 05:36 PM   #8
ronn
iM A BIG FAN OF bARS LEAK- USED IT MANY TIMES IN hs ON OLD JALOPIES AND ALWAYS SEEMED TO WORK.
CAPS..............
Old 03-26-2026, 07:38 PM   #9
Gene F
Gene F's Avatar
Marty, if you can not solder it yourself, call Snyders and order the best one they sell. I had one fixed (for a streetrod) about 7 or 8 years ago, and it was a super big pain finding a shop to fix it.
BTW, I have heard of the teablespoon of black pepper thing.
Gene F is offline   Reply With Quote
Old 03-26-2026, 09:35 PM   #10
Synchro909
Synchro909's Avatar
There are all sorts of old time fixes for a leaky radiator. Here, Bars Leaks is dried chicken poop in oil. The poop is the same as a fertiliser sold here as "Dynamic Lifter. Being in oil, it stays "dry". That is, it contains no water. When added to the radiator, water gets at the poop and as it gets wet, it swells. Any that lodges in the leak will continue to expand, thus sealing it. Ground pepper works the same way, as does dry cow pats etc. I have even heard an egg being broken into a hot system works well.
Sodium silicate works well too. I have in one of my engines that developed a crack in the block about 2,500 miles from home. It got me home and it is still in there. There is no sign of the leak now and I'm driving it as normal.
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say.
I sometimes wonder what happened to the people who asked me for directions.
If I am not in trouble, I've done something wrong.
Old 03-27-2026, 07:25 AM   #11
marty in Ohio
Thanks Synchro. My only problem now is to find a chicken that will poop in my radiator.(LOL)
Marty
Old 03-27-2026, 07:29 AM   #12
Ray64
Ray64's Avatar
Marty there is a radiator shop on CLEVELAND STREET in ELYRIA . seems like THOMAS RAD> rings a bell. Ive used them before. Dont quote me on that name Brain is getting old LOL
Old 03-27-2026, 07:41 AM   #13
Big hammer
Has anyone ever called the manufacturer and asked them if their products are good for non-pressurized cooling systems ? Some of the products need pressure to seal a leak . Have you checked your non-pressurized model A radiator that it is venting, the tiny little overflow tube can get plugged and then cause the cooling system to be pressurized and cause leaking . I’ve used a #12 solid copper wire to clean the little tiny tube , slow and steady by hand pushing through the tube !
get a bigger hammer tap done
Old 03-27-2026, 08:37 AM   #14
Bob Bidonde
Bob Bidonde's Avatar
There is a rivet that connects the radiator's structural frame to the bottom radiator tank that is prone to leaking. Unfortunately, short of taking the radiator apart, stop leak is the only fix I have found that works temporarily.
Bob Bidonde
Old 03-27-2026, 09:50 AM   #15
SAXBY2
Some like Aluma Seal stop- leak, been around for a long time .Use as directed.
SAXBY2 is offline   Reply With Quote
Old 03-27-2026, 02:22 PM   #16
marty in Ohio
Upon further investigation I found that the radiator is not leaking. The leak was at the lower hose. I've got it all apart, cleaned up and painted the lower metal tube, and will put it back together with new hoses.
Ray, the radiator shop that you referred to is Thomas Radiator off Cleveland St. They closed about a year ago. They've always did my work before.
Big Hammer, I've also heard that Bars Leak won't work well in a Model A because the system isn't pressurized.
Always learning.
Marty
Old 03-27-2026, 02:36 PM   #17
Gene F
Gene F's Avatar
I know a guy that put that in before a tour, and it worked.
Old 03-27-2026, 06:34 PM   #18
Synchro909
Synchro909's Avatar
Another good option (I know through experience).
Old 03-27-2026, 07:26 PM   #19
Y-Blockhead
Y-Blockhead's Avatar
That is where my radiator had a small leak. Funny thing was, it would only leak when cold. I was going to pull the radiator and have it repaired "when I had a chance", but we drive our cars year 'round out here.
I asked a few folks and more than one recommended K-Seal for a temporary fix. I poured the K-Seal in and it did nothing to stop the leak. Bottle sez 1-3 minutes...
Then after a couple of weeks, the drip just stopped! Not a drop since, been~6 months now.
I am not a fan of stop leaks, but I asked a few folks and more than one recommended K-Seal for a temporary fix. I poured the 1/2 bottle of K-Seal in as recommended and it did nothing to stop the leak. Bottle sez 1-3 minutes...
Old 03-27-2026, 10:03 PM   #20
CWPASADENA
CWPASADENA's Avatar
I would start with Bars Leak or Aluma Seal. I do not think you need anything as agressive as a block seal.
My opinion,
Chris W.
CWPASADENA is offline   Reply With Quote
