#1 |
All:
I am currently looking at a no charge situation. As part of that, I removed the gen and am testing in the shop. The field shows 3 ohms to ground and the armature about 7 ohms. Hooking up to 6V it motors fine at about 500 to 600 rpm. The commutator looks good but I am going to replace the brushes and clean everything up. The rear bushing looks ok, no scuffing. The current issue for me is that I noticed a lot of out of center rotations while motoring. I checked the movement: 30 thousandths up and down, 15 thousandths laterally. I popped the front plate off and there seems an inordinate amount of wobble, like the front bearing has self destructed. This is not normal, is it? I tried to get the pulley off and no clip or nut. Is it pressed on? The brand name is Hastings and states it is a Replacement Generator. No model number. Hastings was a good company back in the day if this is the same one. I though I would see if anyone was familiar with this one before I destroy it trying to disassamble it. Thanks, Dave
Nothing is foolproof to a talented fool. |
#2 |
After some further looking: could this pulley be threaded on? And the snap ring is just missing?
Thanks, Dave
#3 | |
#4 |
I have a generator that's got pulley threaded onto the armature.
Assembly, tighten pulley with armature in vise. The clip is there to assure that you don't have a problem with it coming off in use... I don't have one either. Karl |
#5 |
I’d say if it doesn’t have a nut, it’s threaded on. I’ve never seen a pulley on a generator that is pressed on.
#6 |
#7 |
Ok thanks! I got it off ok, it was threaded. I found the wobble. The shaft is about 15 to 20 thousandths narrower where the bearing sits on the shaft. See pic. Since this bearing is ok, I would assume this happened some time during a bearing failure and a new bearing was put in without correcting the problem. Anyhow I am thinking this armature is NRTS and, considering the total cost of armature, bearing, brushes etc., and considering how beat up this one is, I will just buy a rebuilt.
Cheers Dave
#8 | |
#9 |
I restore a lot of Ford generators and have seen quite a few armatures that were ruined by spun bearings. I have restored original Ford generators in stock. PM or email me if interested.
Restored Ford 6 & 12 volt generators |
#10 |
If the generator functions ,as is, then look for another armature to replace the worn. 1940 Ford used an armature with the threads and a recess for a ring. You do not show the complete pulley it may be early 1940 if so it will have the indented part number 01A-
#11 |
Steve, I pulled the trigger on another rebuilt before I saw your reply. You are in Fredericksburg which is not too far from me. I will keep you in mind if I need another one.
No part numbers on anything. I assume Hastings ground them all off. Cheers, Dave
