Old 03-19-2026, 12:10 PM   #1
kevinshea
kevinshea's Avatar
Default front and rear blinkers/turn signals. -ideas?
I've seen a few cars set up with small aftermarket yellow turn signals, often mounted on bumpers. I have looked in the past, but not sure I really like to attach one of those turn signal devices to my steering column. I think they look ugly.
any other ideas?
kevinshea is offline   Reply With Quote
Old 03-19-2026, 12:40 PM   #2
Karl Wescott
Karl Wescott's Avatar
Default Re: front and rear blinkers/turn signals. -ideas?
First the "turn signal devices" are nothing more than a stack of switches. With a couple of relays (or transistors) a toggle switch (double throw + neutral) or even 3 button switches could be wired to do the job. There is a wiring diagram posted here: https://www.pinterest.com/pin/527976756306148232/.
Other options for mounting the lamp besides the bumper include inside the grille, on 1936's inside the horn grille. 1970's Chrysler turn signal indicators that mounted on top of the fenders were popular once with street rodders but are now hard to find.
You will be making a modification that will push the car gently in the direction of "street rod"... so be creative! And enjoy. There is no right or wrong, its your car.
Karl Wescott is offline   Reply With Quote
Old 03-20-2026, 06:36 AM   #3
kevinshea
kevinshea's Avatar
Can you post that here.. I don't have pinterest.
Old 03-20-2026, 06:40 AM   #4
The Art Doctor
The Art Doctor's Avatar
Use an early VW switch, they look the part. They are metal, can be painted and fit around the column not sticking off like a zit attached with a hose clamp.
The Art Doctor is offline   Reply With Quote
Old 03-20-2026, 08:26 AM   #5
glennpm
glennpm's Avatar
Thanks Karl, here is a non-Pinterest link
https://web.archive.org/web/20120430...n-signals.html
Archives of historical but relevant older articles:
Hover mouse over the links below and click!
Rumble Seat’s Notes
Techno Source for the 1932 thru 1953 Flathead Ford
Old 03-20-2026, 09:57 AM   #6
TJ
TJ's Avatar
any other ideas?
Look on E-Bay and you'll find an American Auto Wire switch #500148 which is a toggle switch you can hide on a bracket under the dash. I have used them and they work well, but a little pricey compared to the column switch.
Old 03-20-2026, 10:32 AM   #7
kevinshea
kevinshea's Avatar
Glenn .. great info on setting one up.. Thanks
Old 03-20-2026, 10:33 AM   #8
glennpm
glennpm's Avatar
You're welcome. It's a helpful link.
Old 03-20-2026, 03:08 PM   #9
petehoovie
petehoovie's Avatar
Old 03-20-2026, 05:15 PM   #10
FlatheadTed
FlatheadTed's Avatar
I use a switch such as #500148 drilled under the dash ,I have a high stop light /Flasher coupled into the circuit using four 50 cent diodes to stop feedback, four flashers on the bumpers . works great , Ted
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 03-20-2026, 06:37 PM   #11
johndee138
johndee138's Avatar
A Yankee 960 is a very nice deco styled add on. They have gotten pricey though
www.ebay.com/itm/205862614535
johndee138 is offline   Reply With Quote
Old 03-20-2026, 06:55 PM   #12
FlatheadTed
Mine was a simple two way toggal switch from a out let for radio bits we call J car . DPDT 6A 240VAC Heavy Duty Centre Off Standard Toggle Switch
Typically $7.70 , sorry not #500148
Old 03-20-2026, 08:19 PM   #13
petehoovie
petehoovie's Avatar
Vintage Yankee 960 Art Deco Turn Signal Switch Ford Chevy Dodge Rat Rod OriginalVintage Yankee 960 Art Deco Turn Signal Switch Ford Chevy Dodge Rat Rod Original
US $250.00
Old 03-22-2026, 09:20 PM   #14
rickettsbros
What are you putting them on? Hide something under the dash?
rickettsbros is offline   Reply With Quote
