Old 03-12-2026, 12:00 AM   #1
1EarlyA
Default 1936 Ford parts interchange
As I decide what I am keeping from my '36 Ford Fordor parts car, I have / will have some parts I need to know the interchange on, hence the slightly vague title.
1) Do the front bumper brackets interchange with any other years? Pickups?
2) Do the front doors by any chance interchange with a coupe? Seems like I read that once, but my memory is sketchy.
3) the hood stops / bumpers (not sure what they are actually called) that bolt on the top edge of the fenders and the hood draws up against. Do these work on any other years?
4) steering column and gear interchange?
Thanks in advance.
1EarlyA is offline   Reply With Quote
Old 03-12-2026, 12:41 AM   #2
deuce lover
deuce lover's Avatar
Default Re: 1936 Ford parts interchange
Bumper brackets: Outer brackets should work on a pickup.Inner brackets 35,36 same.
Doors will not interchange unless modified.
Hood stops etc you noted are 36 pass car only as are the inner fenders.
Steering column interchanges with 35. Steering gear to me is junk .Replace with a 37-40.
deuce lover is offline   Reply With Quote
Old 03-12-2026, 12:52 AM   #3
1EarlyA
Out of curiosity, what makes the later ones better?
Old 03-12-2026, 01:13 AM   #4
ford38v8
ford38v8's Avatar
1936 was worm and sector.
1937 was worm and roller.
It is possible that your so-called 1936 steering box had already been swapped out for a 1937, as the worm and roller's superiority is common knowledge.
Alan
Old 03-12-2026, 12:37 PM   #5
Karl Wescott
Karl Wescott's Avatar
The front door latches fit all 1935-36 closed cars and cabriolets. The inside handle mount also fits all 1935-36 closed cars and cabriolet, and can be used on most late 1931 through 1940 closed cars and cabriolet. The link between the front door latch and inside handle mount is the same as 5 window and sedan delivery (but can be modified to fit most any year 1931-40). The front door window regulators and glass bottom channels fit all 1936 closed cars (not cabriolet). The internal window channel support guides fit all 1935-36 closed cars. Rear door latch and window parts are 1935-36 fordor only.
None of the above hardware is available in a quality reproduction today so if the doors get scrapped save the hardware.
Karl Wescott is offline   Reply With Quote
Old 03-12-2026, 04:50 PM   #6
1EarlyA
Thanks for all the specific info. It sounds like it would definitely be a good idea to strip the doors out. However, I am getting so overwhelmed, that I may end up trying to sell the shell with doors, decklid, running boards and let somebody else tear it down or build it from there. I really need this out of my way before summer.
Old 03-14-2026, 10:33 AM   #7
oldbugger
oldbugger's Avatar
I have 4dr doors on my 35 coupe. the modification is not that difficult. the coupe door curves down a bit towards the back of the door. Everything else is the same.
oldbugger is offline   Reply With Quote
Old 03-14-2026, 01:07 PM   #8
uncle buck
uncle buck's Avatar
Exactly , it’s a very easy modification to make fit a 35 or 36 5 window coupe. Essentially all you have to do is grind the top edge down about 3/16” at the back edge and blend it forward about a foot. Usually the inner folded edge can be dropped down after you grind the edge and you just need to weld the edge back together when you are happy with the gap. Much easier than rust repair
uncle buck is offline   Reply With Quote
Old 04-09-2026, 12:41 PM   #9
1EarlyA
What are these panels correctly called? They go between the headlight bracket and the front inside edge of the fender.
Old 04-09-2026, 12:46 PM   #10
petehoovie
petehoovie's Avatar
Old 04-09-2026, 04:48 PM   #11
1EarlyA
Also, what is this piece of trim immediately below the garnish called?
File Type: jpg 1936-ford-deluxe-4-door-sedan inside door.jpg (66.0 KB, 212 views)
Old 04-09-2026, 05:03 PM   #12
petehoovie
petehoovie's Avatar
Old 05-15-2026, 11:25 PM   #13
aandkt
I believe that is part of the garnish
aandkt is offline   Reply With Quote
Old 05-15-2026, 11:38 PM   #14
uncle buck
uncle buck's Avatar
That is a deluxe accessory garnish moulding trim
Old 05-16-2026, 07:37 AM   #15
Karl Wescott
I call the "Front fender extension inner fender" for lack of a better term.
Old 05-16-2026, 11:33 AM   #16
RalphM
RalphM's Avatar
My right rear fender on my 35 coupe has a sedan fender grafted to it. They cut most of the original off and leaded the two together. I wish I could find a left rear fender as it is much worse than the right.
RalphM is offline   Reply With Quote
Old 05-16-2026, 03:57 PM   #17
petehoovie
petehoovie's Avatar
Old 05-16-2026, 07:42 PM   #18
oldbugger
oldbugger's Avatar
When i was putting my 35 together 12 yrs ago i found a guy up by Muskegon mi that had a few 35 coupe fenders hanging in his barn, only problem was he wanted about $3000 per pair. so I brazed and patched my originals, would have been better to spend the money.
