Old 03-01-2026, 12:34 PM   #1
old31
Default packing bearings
I have always packed bearings by hand.
Are there any advantages to a bearing packer?
https://www.amazon.com/GearWrench-27...s%2C168&sr=8-9
https://www.amazon.com/gp/product/B0...4505EPYW&psc=1
https://www.amazon.com/gp/product/B0...W6LYJS8K&psc=1
Old 03-01-2026, 12:43 PM   #2
Kurt in NJ
Kurt in NJ's Avatar
Default Re: packing bearings
It’s quicker,you just get greas on your fingertips picking the bearings out of the packer.
— the negative— if the grease is thick and cold it takes a lot of force pushing
If you lend it out most likely it will come back with dirt in it— I always kept 2 in my toolbox— a dirty one to lend out and one only I used.
the bearings have to be already cleaned properly.
Old 03-01-2026, 12:43 PM   #3
cadillac512
cadillac512's Avatar
Not much other than keeping your hands a bit cleaner. By the time the packer is wiped off and put up and you've handled the bearings it's not a lot different. A pair of disposable gloves is the best bet for me.
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'30 Model A Speedster
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 03-01-2026, 01:37 PM   #4
P.S.
I've tried those. Like Kurt mentions, they inevitably end up with dirt or debris in them, and you don't want that in your bearings.
I prefer the old fashion way for many reasons- https://www.youtube.com/watch?v=bIWMJ4RxqF8
This one has my wife cleaning and then packing bearings- https://www.youtube.com/watch?app=desktop&v=i3YU7PAjf1Y
2024-2026 MAFCA Technical Director
P.S. is offline   Reply With Quote
Old 03-01-2026, 07:00 PM   #5
nkaminar
nkaminar's Avatar
When i was a kid, many centuries ago, I would melt the grease in a metal pan over a hot plate, put the bearing in, and then let it cool. The bearings were solid packed. Beware: hot grease is flammable. An old tin can worked well, depending on the size of the bearing and the size of the tin can.
Old 03-02-2026, 12:08 PM   #6
Randall
Randall's Avatar
I like my brg packer and when done I put it in a Walmart bag to keep it clean https://youtu.be/hS__pb4PmPk?si=OdejZNAfZX9PeQkv
Randall is offline   Reply With Quote
Old 03-04-2026, 07:50 PM   #7
whirnot
whirnot's Avatar
My Bearing packer is self contained, when done with it, I put the lid on, wipe it off and put it away. Does a quick and easy job, much easier.
Bill Worden
1929 Roadster
1929 Briggs Town Sedan
1930 Closed Cab pickup
1931 Coupe
2 Smith Motor Compressors
1951 Ford F1
High Desert Model A's
whirnot is offline   Reply With Quote
Old 03-05-2026, 10:47 PM   #8
JayJay
I likewise use a bearing packer, and put it in a gallon ziplock bag between uses. I like that I can see the new grease displacing the old grease around the rollers as I push down. On the other hand, if you're comfortable packing the "old school" way by hand, by all means continue doing so. Nothing wrong with it, we got by a lot of years doing it that way before bearing packers came on the scene (I think I've only had mine the last 15 years or so).
JayJay
San Francisco Bay Area
1930 Murray Town Sedan (under reconstruction)
1931 Briggs S/W Town Sedan
It isn't a defect, it's a feature!
JayJay is offline   Reply With Quote
Old 03-06-2026, 11:40 AM   #9
katy
katy's Avatar
I wash (and dry) the bearings clean before repacking them. so no old grease to watch for.
