Go Back   The Ford Barn > The Swap Meet > Wanted > Early V8
Old 03-01-2026, 08:32 AM   #1
jstrez5
Default 1939 Ford Sedan Door Trim
City: Shavertown
State: PA
I am in need of an interior door trim piece for a 1939 Ford Standard Sedan. The piece I need is located on the front inside door: either left or right side. Some specifics on the piece:
-Measure approximately 31-1/2" long
-Held on with small nails that are welded onto the back of the trim piece
-Attaches to the door via the small nails
-Located slightly above the door and window handle
If you have this piece or any suggestions on where to find this piece is greatly appreciated.
Thanks,
Jim
jstrez5 is offline   Reply With Quote
