Old 02-26-2026, 01:06 PM   #1
1930artdeco
1930artdeco's Avatar
Default AC brackets and toys
Well I got my new parts in that are apparently hens teeth. I apparently got a brand new bell crank for my Y block w/auto. I was not aware that anyone was making a brand new bell crank. It is really nice and tight and comes with a really strong spring. Anyone heard of this?
Also got an AC mount (58) to mount the Compressor over the PS unit with a double belt Gen pulley. I will post pics when I get a chance.
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 02-26-2026, 04:00 PM   #2
Gene F
Gene F's Avatar
Default Re: AC brackets and toys
Where did you get the bell crank?
Gene F is offline   Reply With Quote
Old 02-26-2026, 05:06 PM   #3
1930artdeco
Jerry's auto parts in Arkansas.
1957 Country Sedan
Old 02-26-2026, 06:08 PM   #4
1930artdeco
Hopefully they show up.
1957 Country Sedan
Old 02-26-2026, 07:59 PM   #5
craig
Your bell crank appears to be an original that has been glass beaded. IMO you are better off with this than if there was a repro part
craig is offline   Reply With Quote
Old 02-26-2026, 08:50 PM   #6
paul2748
paul2748's Avatar
Canceled
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 02-26-2026, 08:53 PM   #7
paul2748
paul2748's Avatar
What is it with these ads. First time I have seen these
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 02-27-2026, 12:43 PM   #8
1930artdeco
Craig, that would be awesome if it is! But, I can't find a FOMOCO stamp on it anywhere. And if it is original then it would have to be NOS. Again Awesome!!
Mike
1957 Country Sedan
Old 02-27-2026, 05:04 PM   #9
craig
I have the same thing on my '56, glass beaded it and found no FoMoCo stamps on it either.
Looking at your photo, it appears the mounting holes are slightly etched from the bolts that once held it in place
Old 02-27-2026, 05:12 PM   #10
1930artdeco
OK, I will verify tonight that it will work. IF it does then it gets painted and installed!!! Then I can rebuild my other original.
1957 Country Sedan
Old 02-28-2026, 06:37 PM   #11
Gene F
Gene F's Avatar
Thank you very much
Old 03-31-2026, 02:43 PM   #12
Kube
Super Moderator
Kube's Avatar
Mike
Parts supplied TO Ford would not have the Ford script or (later) FOMOCO on them.
Old 04-01-2026, 10:28 AM   #13
1930artdeco
Thanks Kube. That would explain why no logo. It is used but so lightly it is essentially NOS.
Mike
1957 Country Sedan
