Old 02-25-2026, 11:34 AM   #1
atch
atch's Avatar
Default What cool item have you made from Model A parts?
I was perusing the Barn this morning and came across a thread referencing a walnut cracker made from Model A steering box. This led me to searching for other similar threads but found none.
A friend has a soda/beer can crusher mounted on top of a 55-gallon drum. Wish I had a pic to show. It's also made from a steering box. 55 gallons of crushed aluminum cans brings in a tidy little windfall.
A friend made this slide hammer from a Model A brake rod and gave it to me.
So what other pieces of a Model A have you repurposed into something useful?
atch (Mike Atchley)
Columbia, Missouri
atch is offline   Reply With Quote
Old 02-25-2026, 11:41 AM   #2
rfitzpatrick
Default Re: What cool item have you made from Model A parts?
Beware the Model A Police for destroying parts??
(i like it!)
rfitzpatrick is offline   Reply With Quote
Old 02-25-2026, 01:59 PM   #3
Kurt in NJ
Kurt in NJ's Avatar
I had to make power steering for a overweight golf car ,the front part of the torque tube gave the space to couple the shafts
Old 02-25-2026, 02:20 PM   #4
Ray in La Mesa
Made a fire poker from a brake rod & a clock from a cowl light for the motorhome. Outside door handle to control shutters on oil cooler on '70 VW van & 2 more for garage door handles, flagpole tie down from scroll door handle, coffee table using '29 running board & brackets. Accessories in my "Model A" bathroom: clock using oval instrument panel, 3 cupboard pulls from deck lid handles, toilet paper hanger from leaf spring ends, curtain tiebacks using headlight conduits, towel bars using front bumpers (cut to fit), toilet flush handle using '29 woodie door handle. Used a complete transmission for a speed controller on an ancient vertical mill. Headlights & taillights for yard lights & outer shop lights. Differential castor brackets from 21" wheel hub, wheel true checker from spindle & cut down brake drum to mount on engine stand.
Ray in La Mesa is offline   Reply With Quote
Old 02-25-2026, 02:58 PM   #5
atch
atch's Avatar
Ray,
Can you post any pix. These sound "interesting, very interesting" (said in my best Arte Johnson voice).
I'm sure that most of us would love to see said pix.
atch (Mike Atchley)
Columbia, Missouri
Old 02-25-2026, 04:24 PM   #6
nkaminar
nkaminar's Avatar
A leaf spring, not necessarily from a Model A, makes a good lever for prying abalone off of rocks. I did a lot of abalone fishing on the Big Sur coast when it was still legal back in the early 1970's. You had to sneak up on the abalone because if they felt any vibration in the rock they would clamp down and you could not get the pry bar under them. By rocks, I am referring to ones that were as big as houses. This had to be done at low tide and you had to hold your breath when the waves came in. And wedge yourself in between the rocks so that you did not get washed out to sea. The end of the leaf spring was forged to a thin chisel shape to fit between the rock and abalone. The other end had a hole poked in while the spring was red hot for a lanyard to put on your wrist so that you did not loose the pry bar.
Same location was good for poke-poling. The wire part was made from the wire that held the head liners in on cars. It was attached to a bamboo pole. The wire was curved to fit between the rocks and had a thick piece of 3-foot long monofilament attached with a big hook and piece of squid. You had to be careful not to touch the wire to the rocks as this would scare the fish. If the current was washing in and out between the rocks you knew there was a hiding hole there for a fish.
Old 02-25-2026, 05:27 PM   #7
Brad in Germany
Brad in Germany's Avatar
Saw this one in a European Ford magazine where they have used a 1930 radiator shell as the opening trim of the fireplace:
Other Ford parts in the photo include a rear axel lamp, a differential housing clock on the mantel; plant stand legs were rear springs (or maybe bumpers); not sure what the candle sticks were or the parking brake handle on the wall to the right.
Brad in Maryland
Brad in Germany is offline   Reply With Quote
Old 02-25-2026, 07:38 PM   #8
LEM
LEM's Avatar
Wall clock made from a red 28 steering wheel, headlight switch selector and license plate numbers from Hobby Lobby.
LEM is offline   Reply With Quote
Old 02-25-2026, 09:31 PM   #9
Bigsnapper43
Torque tube for a mount for a SUN DIAL.
Bigsnapper43 is offline   Reply With Quote
Old 02-25-2026, 11:34 PM   #10
Ray in La Mesa
Sorry atch, I haven't figured out how to post pictures yet.
Old 02-26-2026, 02:01 AM   #11
atch
atch's Avatar
Ray,
Check your private messages...
atch (Mike Atchley)
Columbia, Missouri
Old 02-26-2026, 11:11 AM   #12
katy
katy's Avatar
Spring leaves used for tire irons to R&R tires on rims.
Old 02-26-2026, 12:54 PM   #13
Bruce of MN
Bruce of MN's Avatar
Not cool, really, but I used some old radiator support rods to make long studs to repair a couple of card table chairs.
Bruce of MN is offline   Reply With Quote
Old 02-26-2026, 01:46 PM   #14
JoeCB
JoeCB's Avatar
Many old rear axle housings morphed into sturdy jack stands back in the day.
Joe B
JoeCB is offline   Reply With Quote
Old 02-26-2026, 03:29 PM   #15
ursus
Joe B
And, as upright posts for bar stools.
ursus is offline   Reply With Quote
Old 02-26-2026, 09:28 PM   #16
atch
atch's Avatar
Joe B
Yeah. I've got a couple but I don't know what year they came from. All I know is that they are banjo rear bells. Could be anywhere up to '48. I inherited them somewhere 25-35 years ago and I don't remember where/who they came from.
I had forgotten about them until you posted above.
atch (Mike Atchley)
Columbia, Missouri
Old 03-01-2026, 01:56 PM   #17
JOHN CT
JOHN CT's Avatar
How about model t connecting rods an exhaust clamp and a ford step plate It makes a great paper towel holder.
31 Tudor
66 Bonneville
57 Chevy pickup 27 T roadster pick up
JOHN CT is offline   Reply With Quote
Old 03-01-2026, 02:11 PM   #18
P.S.
As seen in background of many Paul Shinn videos - A clock.
File Type: jpg 07E7BA50-2509-44A6-9308-DED6032F9CA3.jpg (78.5 KB, 26 views)
2024-2026 MAFCA Technical Director
P.S. is offline   Reply With Quote
Old 03-01-2026, 06:16 PM   #19
Ray in La Mesa
Used an A connecting rod to build a steering column mount to bypass the gas tank mount. Also used one to mount the cable shifter T handle for my Mitchel o/d on the steering column, but had to hog it out to fit lower on the steering column.
Old 03-01-2026, 10:34 PM   #20
atch
atch's Avatar
Ray, what you said reminded me of something.
Well, I didn't make it, and it's not even a Model A part, but it was IN a Model A so maybe it counts. I was at a car show about 30 years ago and there was a pretty radical Model A coupe hot rod there. When I looked inside I saw the steering column drop was made from a connecting rod (of unknown origin) that had a perfect bend in it. The big end went around the steering column at just the right angle. The piston pin hole had been cut off of the small end and it was perfectly vertical hanging from the dash. I asked the owner how he got that perfect bend in a connecting rod and he said "that's just the way it looked when it came out of the side of the block. I'll never forget that story.
atch (Mike Atchley)
Columbia, Missouri
