#1 |
What screws are used for the interior windshield garnish moldings on a 47 Pickup?
#2 |
The screws I used on my 40 Ford look like this. I remember I bought them at ACE HARDWARE back in 1978. They are slotted. I think the OEM screws were cadnium plated.
https://www.ebay.com/itm/142657231893 |
#3 |
Not sure about trucks being different than cars, but I thought that Ford switched to Phillips screws after the war. My nice original ‘46 Mercury has all Phillips screws in the interior.
#4 |
I got mine in stainless from a West Marine store. Slotted oval head. I was driving my 47 pickup turned woodie on the mainland, so I was able to run one out to the parking lot and test it. My plan was to dull them down on a scotchbrite wheel, but when I finally got around to doing the buffing they turned up missing. Oh and the Ace over there only had them in phillips.
Edit: Art I see you are in Illinois, It was 19fordy that's in Coral Springs Fla. I figured you could just walk into a West Marine store, but maybe not in Hillsboro.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1946 Tonner Pickup with 226 H six, 1979 Toyota landcruiser wagon, now wearing 1947 Ford Jailbar sheet metal. 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) Last edited by GB SISSON; 02-17-2026 at 11:08 PM. |
#5 | |
#6 |
#7 | |
Super Moderator
The original poster needs to find phillips head, oval. Stainless. These should be fairly easy to find. I might try Mike Driskell first just to make the search easy.
#8 |
Screws tend not to have changed over the years. If you have a pattern measure the diameter. Look up a chart to find the screw number. Measure the length. Then search for a screw that length and number with a phillips oval head. Like Mike says, stainless are available and look nice when fitted. I found plenty listed on ebay when I needed some for a different application.
Mart. |
#9 |
Ace Hardware can be your nearest friend with these screws. Get the stainless ones.
