Old 02-16-2026, 07:55 PM   #1
spdway1
spdway1's Avatar
Arrow Amp Meeter for a Model A or...
I found this amp meter in this box, in my stash. It has significant weight to it. Is it a Factory Model A, after-market, for a car from another year or a re-pop? Also, I am suspicious because it has a black bezel. Thank you.
spdway1 is offline   Reply With Quote
Old 02-16-2026, 09:26 PM   #2
Terry Burtz, Calif
Default Re: Amp Meeter for a Model A or...
WW2 era Ford replacement part when plating stopped for the war effort.
Terry Burtz, Calif is offline   Reply With Quote
Old 02-16-2026, 11:06 PM   #3
old ugly
old ugly's Avatar
even if it is not the right color and if it fits the hole, it will be better than any new reproduction amp gauge.
old ugly
my mom would have told me. "these things are here to test us"
old ugly is offline   Reply With Quote
Old 02-17-2026, 12:12 PM   #4
rotorwrench
rotorwrench's Avatar
They original types weren't complicated but they always had that fairly large C-shaped magnet in there to center the needle. The commercials had black bezels but who knows what's under the black paint. The bezels can be replaced along with the glass and face if need be.
Old 02-17-2026, 01:10 PM   #5
spdway1
spdway1's Avatar
Why would the commercials have a black bezel, the dash plate was not black.
Old 02-17-2026, 02:36 PM   #6
Joe K
Joe K's Avatar
Um. The dash AND the gearshift lever COULD be painted black.
On my small truck (avatar Somerville, MA assembly March 1929) the gearshift was painted black. On removing the paint with a stripper was uncovered a "defect" in the nickel plating - apparently painted to cover a gearshift lever "not appropriate" for a regular car - but perfectly fine for the lesser standard of a truck once painted to match the interior trim.
My truck's dash plate was nickel, but I have seen some both on small trucks and AA, that were fully painted black.
Neil Wilson has addressed the ammeter somewhere - but I'm not seeing it in his AA pages.
My original ammeter was probably silvered - but corroded to a dull grey in time.
I replaced it with a (1990s) "high quality" ammeter reproduction = which indeed was high quality construction. Not the lesser quality "aluminum" case more commonly bought.
However, the diameter of the meter was "small." Bending the ears to hold it in the dash plate there was not enough "ear" to hold the case in place.
My solution was to stretch a rubber O-ring around the case and then bend the ears. It looks correct even though a little small.
Joe K
Shudda kept the horse.
Joe K is offline   Reply With Quote
Old 02-17-2026, 04:21 PM   #7
redmodelt
redmodelt's Avatar
1926/27 Ford Model T used the same size meter as did a large number of cars, trucks, tractors etc.
Old 02-17-2026, 04:36 PM   #8
Joe K
Joe K's Avatar
The same meter (or at least a very similar call-out identifier) was used by Ford until nearly WWII.
Joe K
