Old 02-13-2026, 03:05 PM   #1
bosscat28
Default 59 AB in 35 ford maxing out oil pressure gauge
I have a 59AB in a 35 Ford truck with a oil pressure/fuel gauge in it.
It maxs out over 50 lbs at an idle.
I have a new 50 lb sender from C&G
What would cause this.
Possibly a defective sender???
We buy our problems
bosscat28 is offline   Reply With Quote
Old 02-13-2026, 03:12 PM   #2
JayChicago
JayChicago's Avatar
Default Re: 59 AB in 35 ford maxing out oil pressure gauge
Does it also max the gauge with key on / engine off?
JayChicago is offline   Reply With Quote
Old 02-13-2026, 03:15 PM   #3
tom1948
does it have a pressure relief in the pump?
tom1948 is offline   Reply With Quote
Old 02-13-2026, 03:34 PM   #4
bosscat28
It reads 0 with the key off
5 lbs with the key on not running
maxs out past 50 while running at an idle
I don't know if it has a pressure relief in the pump.
It's still 6V pos ground
I bought the truck last year. It didn't have an oil pressure gauge or sender.
I bought a dual gauge set up oil pressure - fuel gauge.
Got a 50 lb sender & just hooked it up today.
We buy our problems
Old 02-13-2026, 05:58 PM   #5
GB SISSON
GB SISSON's Avatar
Maybe just a really new engine...Is it 50 lb idle cold or also hot? See if you can thread in a manual gauge for a second opinion.
Old 02-13-2026, 06:20 PM   #6
Brian
Brian's Avatar
'5 lbs with the key on not running'
This should read zero...I'd suspect the sender unit
Unfortunately, two half wits don't make a whole wit!
Brian is offline   Reply With Quote
Old 02-13-2026, 08:32 PM   #7
hueyhoolihan
usually gauges and senders are made to work together to register correct pressure. i might expect a mismatched set to show too low or too high, but not an accurate amount of pressure. IIRC, there's an 80lb sender available too, if it were me, i'd try one of those ( https://www.ebay.com/itm/39176118369...tion=view_item ) and seriously consider purchasing one of these too...good luck.
https://www.walmart.com/ip/Oil-Press...ionGroupCode=1
hueyhoolihan is offline   Reply With Quote
Old 02-13-2026, 09:10 PM   #8
deuce5wndw
deuce5wndw's Avatar
Temporarily put a mechanical gauge on it that will tell the tale.
deuce5wndw is offline   Reply With Quote
Old 02-14-2026, 12:20 PM   #9
JayChicago
JayChicago's Avatar
Agree.
Old 02-14-2026, 12:23 PM   #10
deuce lover
deuce lover's Avatar
Hunt down an orig 50 lb sender.From what I have heard those repros are inaccurate.
deuce lover is offline   Reply With Quote
Old 02-14-2026, 12:27 PM   #11
JayChicago
JayChicago's Avatar
Originally Posted by hueyhoolihan View Post
gauges and senders are made to work together to register correct pressure. IIRC, there's an 80lb sender available too, if it were me, i'd try one of those
First sentence above is correct. Second sentence is BAD advice. This is a 50 psi gauge, needs a 50 psi sender.
Old 02-15-2026, 01:04 PM   #12
bosscat28
Default Re: 59AB in 35 ford maxing out oil pressure gauge
I have a mechanical gauge that I wanted to try but unfortunately I can't find it.
I've ordered another sending unit from Carpenter. I would guess the one I bought from C & G was probably made by Carpenter too.
We buy our problems
Old 02-15-2026, 01:36 PM   #13
glennpm
glennpm's Avatar
0-60 psi gauge and cheap
https://www.amazon.com/gp/aw/d/B0D6V...d_asin_1_title
Old 02-15-2026, 02:01 PM   #14
69a
Does it have a 80 lb pump? I was told 10 years ago that 80 lb was all you could get.
I suggest you find out what pressure you are dealing with before you go any further.
69a is offline   Reply With Quote
Old 02-15-2026, 02:04 PM   #15
deuce_roadster
deuce_roadster's Avatar
The stock senders will only accurately work with a stock gauge and vica versa. These were King Seeley brand and only work correctly with each other. Same goes with the fuel gauge.
Old 02-16-2026, 07:13 AM   #16
51woodie
51woodie's Avatar
When I Bought my '46 Super Deluxe, 59AB, the only gauge that worked was the ammeter. I didn't want to drive it not knowing the oil/temp readings, so I installed accessory gauges. They were intended to be temporary, but I decided to leave them in and include a vacuum gauge. The included pic will show what pressures I have. I later learned how to get the original gauges working, and they somewhat match what the accessory gauges indicate.
51woodie is offline   Reply With Quote
Old 02-16-2026, 11:56 AM   #17
petehoovie
petehoovie's Avatar
Old 02-23-2026, 06:16 PM   #18
bosscat28
Here is my update.
I bought a new sender from Dennis Carpenter. It reads 0 regardless of the RPM, without any teflon tape.
The previous unit from C&G went off the scale high.
I grounded the wire temporarily with the Carpenter unit & the gauge immediately reacted, but went back to zero when the wire was removed.
I found my mechanical gauge and installed it. The engine reads around 32 lbs at an idle and 35 when slightly revved.
I have to agree with the previous post that the aftermarket senders are JUNK!!! I've looked for originals without success.
We buy our problems
Old 02-23-2026, 07:49 PM   #19
hueyhoolihan
i recently installed (successfully) a new oil pressure sensor, 4" sensor extension, and dashboard gauge in my '41. i also had to fabricate and install the solid brass/copper plate that runs power from the gas gauge power stud to the oil pressure gauge power stud to as someone had removed it. an insulated wire will not do, it needs to be a raw plate of conductive material in order to dissipate heat properly, from what i can tell. in any event an insulated wire in its place almost caused me an electrical fire on two occasions. good luck.
the new extender and the NOS dash gauge were purchased from Ebay, the oil pressure sensor was bought from one of the usual suspects and was recently manufactured. everything worked well. YMMV of course.
Old 02-23-2026, 07:58 PM   #20
1942deluxe
1942deluxe's Avatar
There's a NOS 50 LB sender on eBay right now, eBay item number:147032870427.
Bob Selzam is the seller, and his stuff is always good. Price is $159 but I've seen them bring more.
