Old 02-13-2026, 01:02 PM   #1
garys57
Default Ford country sedan accelerator pedal
HI, Guy's has anyone delt with the Accelerator Pedal that was used early1957 full size, in this case wagon, with the 312 dual 4 barrels and overdrive? the reproduction Dennis Carpenter or the one with the round button won't fit. The linkage has a oblong hole and a pin with to different side ends sizes and thicknesses rides in the linkage hole. The parts book shows it but no picture how the pin sits in the pedal? I do not have the original pedal. Any idea's?
garys57 is offline   Reply With Quote
Old 02-13-2026, 11:32 PM   #2
miker98038
miker98038's Avatar
Default Re: Ford country sedan accelerator pedal
I can’t help with the pedal, but a full size E code with the stick/overdrive is really cool. Original, or someone put it together?
miker98038 is offline   Reply With Quote
Old 02-14-2026, 01:21 PM   #3
garys57
nope this is a original Country Sedan 4 door wagon with a single 4 barrel three on the tree with overdrive.
Old 02-16-2026, 12:32 PM   #4
1930artdeco
1930artdeco's Avatar
I will be following this thread! I have the same car with just a single 4 bbl. carb. I know there were two different pins in 57 I just can't remember the sizes.
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 02-21-2026, 01:31 PM   #5
Jeff Norwell
Jeff Norwell's Avatar
There is an early and late pedal.I extensively discussed this on my 57 Threads on the Hamb.
Jeff Norwell is offline   Reply With Quote
Old 02-22-2026, 10:35 AM   #6
cos
Hi Sent you a PM
cos is offline   Reply With Quote
Old 02-22-2026, 12:56 PM   #7
Gene F
Gene F's Avatar
My 1957 Fairlane has the "bus driver pedal", and the pin is not used on my car. Accelerator pedal works just fine. No one has ever even asked about it.
Gene F is offline   Reply With Quote
Old 03-11-2026, 08:49 AM   #8
garys57
Interesting as to a couple responses not sure they read my message, thanks anyway for the responses! I know that this style pedal was used in 57 fords with either a dual 4 barrel or a single 4 barrel. the parts book 'kinda' gives a part number and shows the pin that holds the pedal to linkage. But in the reference book shows one pedal. but the linkage is Not unique? Found a used one in new Mexico but again no reference to the kick down? Ford was good for using various parts! Hard to understand though is that there is not more information out there?
Old 03-22-2026, 10:30 AM   #9
garys57
"Cos" did not receive the PM
Old 03-22-2026, 05:28 PM   #10
russonator
russonator's Avatar
Gary,
I'm not quite sure of your question, but will describe how my early '57 Ford operates.
The pin is spring loaded and passes through the hole in the accelerator linkage and is secured at each end by fitting into holes under the pedal. When correctly installed, you can no longer lift the pedal away from the linkage rod.
My '57 is an E-code Club Sedan with overdrive assembled in January of '57. It has the early ashtray and the one piece radio/heater bezel of the early cars. My pedal and pin are DC repops and operate as designed for both accelerator and kickdown functions.
If you don't find your answer here, you might look into the Fords of '57 FB group. Lots of '57 expertise there.
Hope this helps,
Russ
1939 Ford Standard Coupe
1950 Ford Custom Deluxe Club Coupe
1957 Ford Fairlane 500 E-Code Club Sedan
1966 Ford Deluxe Ranchero
russonator is offline   Reply With Quote
Old 03-22-2026, 06:23 PM   #11
Gene F
Gene F's Avatar
Early ashtray...I never heard that before. I wonder which one I have.
Old 03-22-2026, 07:47 PM   #12
russonator
russonator's Avatar
On early models the door slides down to expose the tray. On later ones the door and tray pull out on a hinge.
