#1 |
Who makes quality carpet for 34 Tudor sedan?
#2 |
A custom auto upholstery shop. You can find the authentic square weave carpet on line easily. Order by the yard and you'll have to have someone make it.
https://relicate.com/collections/ger...e-weave-carpet https://apexleather.com/apex-ultra-square-weave/ |
#3 |
To answer your question as succinctly as possible - Whoever the best upholstery shop in your town is. Currently there is NO company making any "correct" interiors for your 1934 Ford. IF there was, "technically" they would not have what you want either as your car "originally" had a rubber floor mat, NO carpet in the front compartment, carpet was the rear passenger compartment only for Deluxe models, and a rubber mat for the Standard model in the rear. This is "IF" correctness (As Ford made it is your goal).
#4 |
Here is the carpet of a '33 tudor I owned. The rear was done by LeBaron Bonney ,no longer in business.I ordered several yards of the same dye lot when I bought the interior kit.I found some large cardboard and made a pattern.I then had an upholsterer transfer that pattern to the carpet and sew it up.
#5 | |
#6 |
#7 |
Thanks nice. Thanks
#8 |
Check with Third Gen in TN.He is a member here.$229 and in stock.No rears.https://thirdgenauto.com/product/new...original-type/
#9 |
As said of correctness is important the never mind. I’m in the process of doing my ‘39 Tudor standard. I got my carpet from automarinepro https://automarinepro.com/. Made by Dorsett. I got the Essex and have done the install my self. This product is very flexible and I was able to do it in one piece. It formed nicely around the tunnel and transmission cover.
Cheers, Jim&Sandy McGregor, IA |
#10 |
Miniceptor86
"As said of correctness is important the never mind" I guess that's up there with what they say about opinions? |
#11 |
Another vender in the ring........Upholstery Supply USA
