Old 02-08-2026, 02:23 PM   #1
19Fordy
19Fordy's Avatar
Default Odd shaped 3/8 in. socket
I found this 3/8 in. drive socket with both flats and hex. I never saw one before. It appears that it was originally made as a hex socket but, then went through one more manufacturing step whereby every other raised hex was pressed down and removed. The only marking is USA. No size is specified but, it measures 1 in. across the inside flats. Any ideas as to its maker or origin? Thanks.
Old 02-08-2026, 03:13 PM   #2
KiWinUS
KiWinUS's Avatar
Default Re: Odd shaped 3/8 in. socket
Oil pressure sender socket for certain types.
Old 02-08-2026, 03:23 PM   #3
Doublepumper
Doublepumper's Avatar
Don't know for sure, but I believe it's a socket for an elect. oil pressure sensor.
Ever stop to think and forget to start again?
Doublepumper is offline   Reply With Quote
Old 02-08-2026, 03:24 PM   #4
Mart
Mart's Avatar
Or maybe hydraulic brake switch??
Old 02-08-2026, 04:16 PM   #5
19Fordy
19Fordy's Avatar
THANK YOU very much for the responses. It sure does qualify as an oil filter sender socket or brake switch socket. I learned something new today. No more Channel Locks. Thanks, Jim
https://www.amazon.com/Performance-T...e%2C124&sr=1-8
Old 02-08-2026, 05:30 PM   #6
Ggmac
Oil pressure sender socket .
Ggmac is offline   Reply With Quote
Old 02-08-2026, 06:24 PM   #7
hueyhoolihan
a godsend is what this was!
https://www.npdlink.com/product/oil-...fitting/107487
hueyhoolihan is offline   Reply With Quote
Old 02-08-2026, 11:37 PM   #8
farmertom
farmertom's Avatar
19Fordy, don't know about the strange socket,never seen one but i had one of those old life guard stanley tape.yours has alot of miles on her. mine was so warn hardly read anymore. alot of measure 4 times cut or drill once.
farmertom is offline   Reply With Quote
Old 02-09-2026, 10:12 AM   #9
19Fordy
19Fordy's Avatar
farmertown: ACE Hardware still sells those tapes.
https://www.acehardware.com/departme...ools_All_Other
