Old 02-07-2026, 05:08 PM   #1
Ford Freak
Default 14" wheels on a '56?
Hello All! I know that my car came w/15" wheels. Do you all think 14''wheels would look ok on a'56 Fairlane Club Sedan? Reason that I ask is because I have a nice set of "old school" 14" x 6" chrome reverse wheels that I think might look ok on my black '56. I know that Ford went to 14"s in '57 w/the lower profile body that year. Chevy also went to 14"s in '57, with their higher profile body that year, and the 14"s look good on them. Thought's? Thanks in advance! F F
1952 Ford F1
!956 Fairlane Club Sedan
1965 Falcon Sprint
2007 Mustang GT
Ford Freak is offline   Reply With Quote
Old 02-07-2026, 06:14 PM   #2
miker98038
miker98038's Avatar
Default Re: 14" wheels on a '56?
I saw your post on another site. Reminded me my buddy has 14” chrome reverse on a 56 Nomad. In place of the original 15’s. Just because it looks good on the “other” brand tri 5 doesn’t mean it will on yours, but it probably will. If you pick the right tire, or drop the suspension a bit. 14” tires aren’t that easy to come by, so there’s that.
The big tire chain by me has (or had) a photo shop deal, put in the car picture, it “ shops” wheel and tire combos before you buy. With a side view of the car, picture of the wheels, and shopping for tires, they might be able to help.
miker98038 is offline   Reply With Quote
Old 02-07-2026, 07:35 PM   #3
Ford Freak
Good point. Thanks Mike!
1952 Ford F1
1965 Falcon Sprint
2007 Mustang GT
Old 02-12-2026, 04:03 PM   #4
34pickup
34pickup's Avatar
Back in the 60s I ran 14s on my 56 2door and I thought they looked really good.
Matt 24:36-41
34pickup is offline   Reply With Quote
Old 02-14-2026, 10:21 AM   #5
Ford Freak
We are only talking 1/2 in. on the top, & 1/2 in. on the bottom. Not much different, but rpm's will be a bit higher @ 70 mph. The 14' wheels I have here have 215/75/R14 (26.7" tall) tires on them. In the spring, I'm going to slap them on & see how it looks.
1952 Ford F1
1965 Falcon Sprint
2007 Mustang GT
Old 02-14-2026, 10:43 AM   #6
Ford Freak
My owners manual says that the original tires for '56 Fairlane are 670-15. They are 28.6" tall. So, almost 2" taller than the tires that I have. The car has a 1957 Ford 9" rear axle w/3:89 gears.
1952 Ford F1
1965 Falcon Sprint
2007 Mustang GT
Old 02-14-2026, 12:32 PM   #7
5851a
The upper ball joint will be very close to the sidewall of the tire, just a 6-inch-wide tire can rub on the upper a arm. With 14's.
5851a is offline   Reply With Quote
Old 02-14-2026, 12:36 PM   #8
Ford56
Ford56's Avatar
About 15 years ago I switched my '56 Fairlane's bias ply tires for radials, and although they were only about an inch or so lower, it took me a long, long time to get used to the difference in the height. Just didn't look "right" to me.
Ford56 is offline   Reply With Quote
Old 02-14-2026, 04:18 PM   #9
Ford Freak
Thanks, I will check that in April, when it warms up around here & I get back out to the garage!
1952 Ford F1
1965 Falcon Sprint
2007 Mustang GT
Old 02-14-2026, 04:21 PM   #10
Ford Freak
That's what I am afraid of. Thanks for the reply!
1952 Ford F1
1965 Falcon Sprint
2007 Mustang GT
Old 02-14-2026, 10:20 PM   #11
miker98038
miker98038's Avatar
Aerostar springs in the front. Blocks in the back. It’s not that the tire are too short, the car’s too high.
Opps, I try to keep the hot rod impulses under control here. LOL
Old 02-14-2026, 11:41 PM   #12
Ford Freak
Originally Posted by miker98038 View Post
Aerostat springs in the front. Blocks in the back. It’s not that the tire are too short, the car’s too high.
Hmmm.....I think you might have something there! "Hot Rod Impulses" are ok w/me, as my car is quite "Hot Rodded" now. LOL
1952 Ford F1
1965 Falcon Sprint
2007 Mustang GT
Old 02-23-2026, 03:19 AM   #13
Abe Lugo
Can you post pics of your chrome reverse wheels? Just wonder if the have that bead molded in them. Also when you get the on the car. It would be cool to see
Abe Lugo is offline   Reply With Quote
Old 02-23-2026, 12:37 PM   #14
Ford Freak
I don't know what you mean by 'bead". They are just like OEM style, (except chrome). Right now they are on narrow w w. It will be April by the time I get back out to the garage, too cold now!
1952 Ford F1
1965 Falcon Sprint
2007 Mustang GT
Old 02-23-2026, 02:03 PM   #15
Abe Lugo
I would say your rims size/tire is a wash if the tire size overall is the same as the OEM diameter. you would not want to go any smaller than a 8.00-14 or close P215/75R14, that would stock on a '57. If the stock 56 tire was taller than that, then adding this combo will get you some lowering. I would also also say lowering the suspension a bit helps with the look.
Some people stick to 15s for the tire options.
here are the beads Im talking about. I think these were the safety beads people talk about right?
Old 02-24-2026, 08:28 PM   #16
Ford Freak
Abe - mine do have that bead. As far as tires go, according my owners manual, my car would have come w/6.70-15 tires @ 28.5 circum. The closest 14 in. rad. is 235/75/R14, @ 28 in. circum. My car has a '57 9" rear end installed by a previous owner. I have not done the driveshaft thing to determine the ratio, but from 50 yrs. of experience I'd say it has 3:50's - 3:89's. Either way, the 215/75/R14's @ 26.5 would raise my rpm @ 70 much more than I want. Thanks! F F
1952 Ford F1
1965 Falcon Sprint
2007 Mustang GT
