Go Back   The Ford Barn > To The Editors > Questions & Suggestions
Old 02-06-2026, 11:07 AM   #1
Sharky1963
Default Lower radiator hose
My 47 flathead lower hose won’t stop leaking after replacement! Any thoughts? I sanded the neck on the block and installed a new hose because the older previous hose was also leaking.
Sharky1963 is offline   Reply With Quote
Old 03-09-2026, 01:40 PM   #2
olivia_49
Default Re: Lower radiator hose
If the new hose is still leaking, the neck on the block might still be a bit pitted or not perfectly round, which is common on old flatheads and can stop the hose sealing properly. Also check the clamp and make sure the hose is fully seated, sometimes a better clamp or a thin smear of sealant helps seal those small imperfections.
olivia_49 is offline   Reply With Quote
