Old 02-03-2026, 09:41 PM   #1
3twinridges
3twinridges's Avatar
Default KR Wilson bearing retainer ring tool
Anyone had any experience using the kr wilson 2240-n rear axle bearing retainer ring remover? I tightened it down on the ring pretty tight with the chisel like teeth in the jaws and nothing happened.
JB
3twinridges is offline   Reply With Quote
Old 02-04-2026, 02:15 AM   #2
ford38v8
ford38v8's Avatar
Default Re: KR Wilson bearing retainer ring tool
As I understand it (I haven't used it), the jaws merely grab the retainer ring, it'll sit there forever waiting for you to pull it out. Now, maybe someone that knows what he's talking about can follow up with better info?
Alan
Old 02-04-2026, 10:26 AM   #3
Terry,OH
Terry,OH's Avatar
2240-n does not sound like a Ford tool Can you post a photo.
Old 02-04-2026, 11:26 AM   #4
Bob C
Is this the tool?
Old 02-04-2026, 11:38 AM   #5
3twinridges
Yes, that is it! I think one issue I had is that the teeth were diagonal and not vertical. The teeth pop out so I fixed that. One tooth was pretty badly worn/chipped so I ordered a new 3/8 dowel and will grind it down to fix that.
Old 02-04-2026, 12:25 PM   #6
petehoovie
petehoovie's Avatar
Originally Posted by Bob C View Post
Is this the tool?
