Old 01-30-2026, 09:55 PM   #1
91A-77B
Default 1937 Ford rear axle ratio
I recently pulled the rear axle and replaced it with a Columbia. I want to sell it, and believe it's a 3:54 ratio. What's the best way to confirm the ratio?
91A-77B is offline   Reply With Quote
Old 01-30-2026, 10:07 PM   #2
big deuce
big deuce's Avatar
Default Re: 1937 Ford rear axle ratio
On the bottom of the center banjo casting, the ratio... or tooth count is stamped. Yours should be stamped 39/11
big deuce is offline   Reply With Quote
Old 01-30-2026, 11:29 PM   #3
ford38v8
ford38v8's Avatar
Big Deuce's advice does not take into account the real possibility of your ring/pinion having been replaced, and as a matter of fact, 3.54 was not a stock ratio in 1937. If the banjo and axles are out as a complete assembly, a positive confirmation would be to put a wrench on the pinion spline and turn it the 3.54 revolutions you believe to be your ratio, while one axle is stationary, the free axle will have turned two revolutions. On the other hand, if you have removed the axle housings from the banjo, just count the teeth on the ring gear.
Alan
Old 01-31-2026, 12:13 AM   #4
big deuce
big deuce's Avatar
Yes, very true! Not safe to assume...
Old 01-31-2026, 01:09 AM   #5
petehoovie
petehoovie's Avatar
Old 01-31-2026, 09:25 AM   #6
glennpm
glennpm's Avatar
This will give you a pretty good ball park of the ratio, which can be compared with known ratios (4.11, 3.78, 3.54) to see which one comes closest. For example, put a mark on the brake drum, straight up or down is convenient, then rotate the pinion or engine in high gear, 2 revolutions. If the brake drum mark indicates slightly less than one turn for the two pinion rotations, it indicates lower, higher number ratios such as 4.11 or 4.54.
DETAILS:
- Make a chalk mark on the bottom or top of the tire or brake drum
- Rotate the engine or pinion shaft clockwise exactly 2 revolutions.
- Measure the rotation on the tire or brake drum. It will be plus or minus one turn.
- Take this tire or drum rotation value, divide it into 1 (in other words, find its reciprocal),
- Then multiply it by 4.
EXAMPLE:
4(1/X) = 3.54
X = 1.12 (Drum or tire rotation value)
CLOCK BIG HAND INDICATION:
1.12 x 12 = 13.44 or about 10:30
A) Between 1 and 2 o'clock, ratio is 4.44
B) Between 12 and 1 o'clock, ratio is 4.11
C) Between 11 and 12 o'clock, ratio is 3.78
D) Between 10 and 11 o'clock, ratio is 3.54
GRAPHIC
Archives of historical but relevant older articles:
Hover mouse over the links below and click!
Rumble Seat’s Notes
Techno Source for the 1932 thru 1953 Flathead Ford
Last edited by glennpm; 02-01-2026 at 08:47 AM. Reason: Changed values for forward motion
Old 01-31-2026, 10:19 AM   #7
motordr
A car that was originally a V8-60 came with a 4.44:1 ratio. I believe your car was a V8-60, but Al Lobsinger probably changed the rear when he restored it.
motordr is offline   Reply With Quote
Old 01-31-2026, 06:39 PM   #8
hueyhoolihan
Originally Posted by glennpm View Post
This will give you a pretty good ball park of the ratio, which can be compared with known ratios (4.11, 3.78, 3.54) to see which one comes closest. For example, put a mark on the brake drum, straight up or down is convenient, then rotate the pinion 2 turns. If the brake drum mark indicates slightly less than one turn for the two pinion rotations, it indicates lower, higher number ratios such as 4.11 or 4.54.
DETAILS:
- Rotate the engine or pinion shaft exactly 2 revolutions.
- Measure the rotation on the tire or brake drum. It will be plus or minus one turn. Accuracy with these measurements is critical.
EXAMPLE:
4(1/X) = 3.54
.12 x 12 = 1.44 or about 10:30
excellent advice! better cannot be had!
hueyhoolihan is offline   Reply With Quote
Old 01-31-2026, 07:07 PM   #9
fordv8j
fordv8j's Avatar
Our 38 dlx buss coupe had alow speed gear, didn't know what till I had 3-54 gears installed bynthe coumbia guys in Tennessee; found out it was a 4-44,someone probably switched it, or maybe was for running these WVa hills, sometimes you can't see the numbers on the housing, to much rust
fordv8j is offline   Reply With Quote
Old 01-31-2026, 10:16 PM   #10
ford38v8
ford38v8's Avatar
Richard, back when parts were available in junk yards, popular ratio differentials were quickly snapped up, while the left-overs were usually 4.44’s. Later scroungers had little choice. That’s apparently what had happened with both your coupe and with my convertible coupe.
Alan
Old 02-01-2026, 09:09 AM   #11
The Art Doctor
The Art Doctor's Avatar
Glenn, Thank you for your excellent description. My '34 rear end housing is stamped with only 9-3 with no final digit and I have been wondering what it could be ratio wise. I will do your test when I next can.
The Art Doctor is offline   Reply With Quote
Old 02-01-2026, 09:13 AM   #12
ssffnomad
ssffnomad's Avatar
Drain Oil.
Let it drip overnight.
Take a long skinny paint brush, reach in and put white paint on a gear .
With a good light , count the gear teeth till white mark comes back around.
ssffnomad is offline   Reply With Quote
Old 02-01-2026, 09:38 AM   #13
glennpm
glennpm's Avatar
Good!
3.54:1
11 ÷ 39
39 teeth (ring gear) ÷ 11 teeth (pinion gear) = 3.545 ≈ 3.54:1
3.78:1
9 ÷ 34
4.11:1
9 ÷ 37
4.55:1 ratio
9 ÷ 39
Rumble Seat’s Notes
Old 02-01-2026, 10:15 AM   #14
Mart
Mart's Avatar
A video I made some years ago. No difficult maths involved.
https://youtu.be/bkvp3Fq21ZM
Notes:
You turn the hub exactly twice.
The other hub is locked, it does not turn.
The number of turns of the pinion = the gear ratio.
Mart.
Mart is online now   Reply With Quote
Old 02-01-2026, 10:21 AM   #15
deuce lover
deuce lover's Avatar
Since its a 1934 it will be 9-37.There was no 9-34 in '33,'34.
deuce lover is offline   Reply With Quote
Old 02-01-2026, 01:33 PM   #16
glennpm
glennpm's Avatar
Mart.
Yes, but you still have to do some pencil work :-)
Old 02-01-2026, 01:54 PM   #17
ford38v8
ford38v8's Avatar
Are there really people today that remember how to use a pencil?
Alan
Old 02-02-2026, 06:40 AM   #18
glennpm
glennpm's Avatar
Mart's "pencil work"
Rumble Seat’s Notes
Old 02-02-2026, 07:54 PM   #19
The Art Doctor
I did assume it would be 4.11 if it was still stock inside having the 9 tooth pinion. But as this car has been apart before there is no telling what I will find inside. They messed with everything I have taken apart so far and it would not surprise me to find it was changed out.
Old 02-03-2026, 12:26 AM   #20
deuce lover
You can put a 10 spline 35,36 3.78 in a 33,34 rear but the pinion bearing surface has to be machined to accept the 33,34 pinion.Then the driveshaft has to be shortened slightly. 3.78 was not offered in 33,34.
