Old 01-11-2026, 11:04 AM   #1
Tudie 36
Tudie 36's Avatar
Default Ford 94 carb and vapor lock
Trying to track down a vacuum leak, would a small tear in float bowl gasket cause no flow? I can force air into tank fill and gas flows good into a jar, hook up to sediment bowl and nothing. I'm in process of changing vacuum advance; it looks like someone tried to turn the non-turning nut where line connects and bent it at an angle and also replacing gasket on sediment bowl. I have had to force air prime before, but she has always primed in the past.
Thanks, Greg
Tudie 36 is offline   Reply With Quote
