Old 01-10-2026, 06:19 AM   #1
Gene1949
Gene1949's Avatar
Default Non ethanol gas
Been thinking about this for a while. A quick question for the true believers in "non-ethanol" gas.
What is the anti knock chemical used? How does it affect the components of the fuel system?
Gene1949 is offline   Reply With Quote
Old 01-10-2026, 10:29 AM   #2
The Art Doctor
The Art Doctor's Avatar
Default Re: Non ethanol gas
Technically the ethanol is anti-knock at 110 octane by itself that is why its run in race cars with high compression. For non-ethanol fuels common "rocket fuel" additives back in the day were benzene, toluene and xylene which all are around 100-120 octane individually. When they were cheap guys would add a gallon of them to the tank of regular to make high-test in areas where it was not available. Now toluene is regulated and hard to find and xylene is over $25 a gallon so its just cheaper to buy premium from the pump rather than mix your own. The octane boosters in a small bottle are nothing more than benzene (naphtha) and a touch of xylene at a huge mark-up.
The Art Doctor is offline   Reply With Quote
Old 01-10-2026, 05:41 PM   #3
hueyhoolihan
agreed as to previous post.
but to put it another way...
octane is added to gasoline to suppress knocking (detonation) in both ethanol and non-ethanol gasoline, AFAIK. however, the amount of octane added to base non-ethanol gasolines is greater than that added to base ethanol gasolines. most likely because ethanol alone has a pretty high octane rating.
hueyhoolihan is offline   Reply With Quote
Old 01-11-2026, 05:43 AM   #4
Gene1949
Gene1949's Avatar
Very informative replies, thank you gentlemen. However, they don’t address the basic question. The toxicity (just handling those chemicals) is well known, hence the regulation and pricing. Increasing the amount used to achieve the anti-detonation characteristics of fuel destroys (I think) the old style pre-ethanol carb and fuel pump kits. We also know what using ethanol fuel does to the pre-ethanol carbs, pumps and hosing
My belief the “true believers” having so much trouble with their fuel systems is because they refuse to upgrade to 30R7 hosing and buying rebuild kits (fuel pumps and carbs) that are ethanol compliant.
How I know; when I bought the 49 40 years ago drove it home and ran great. Soon thereafter I started having fuel issues. Crap in the carb and a destroyed fuel pump. After a skull session with the local parts guy, he put me onto the idea my entire fuel system needed an upgrade to ethanol compliant kits and cleaning out the fuel tank. Problems solved and been running whatever came out of the local gas pumps since.
My story and I'm sticking to it
Old 01-11-2026, 06:28 AM   #5
hueyhoolihan
sounds reasonable to me!
i didn't go to any great lengths in updating my fueling system, but i did replace most of it from the firewall forward. the pump was a mess and i replaced that along with the carb, but i, for the most part, attributed the damage and failures to age. but i'm ready to entertain the possibility that it was all due to the ethanol. ...if figure i can never have too many things to blame my troubles on. ha
Old 01-11-2026, 07:08 AM   #6
ScubaChief60
ScubaChief60's Avatar
Allow me to weigh in here with a question.
When I was rebuilding my 1935 21 stud 85HP a few years back... I read that there were three components that I needed to upgrade so that I could use either Ethanol or pure gasoline. I made these upgrades as follows:
[The parts I replaced with ethanol resistant ones were]
#1 - the flexible hose that connects the metal fuel line to the mechanical fuel pump,
#2 - the mechanical fuel pump diaphragm,
#3 - my Holley Model 94 carburetor accelerator pump.
Even with these upgrades I have used nothing but pure gasoline... so here is my question. Are my upgrades sufficient for the use of ethanol and pros and cons of ethanol use over pure?
Thanks all!
ScubaChief60 is offline   Reply With Quote
Old 01-11-2026, 07:19 AM   #7
Gene1949
Gene1949's Avatar
Thanks all!
I think you are good to go IF you cleaned out the fuel tank as well.
Old 01-11-2026, 07:30 AM   #8
Gene1949
Gene1949's Avatar
One other story. My ’69 RS/SS big block brand X car with a Demon carb (Holly knockoff). Bought a Berry Grant kit. Ran great for a couple of years. One afternoon flooded out at every stop sign. Replaced the gaskets, generally typical Holly problem. Pulled the primary and secondary float valves and the little “O” ring seals on the needle and seat assembly had shrunk and deteriorated.
Old 01-11-2026, 08:49 AM   #9
ScubaChief60
Yes... the original tank was was beyond repair... so replaced it with a new one Thanks!
Old 01-11-2026, 09:42 AM   #10
pistonbroke
I've taken many carb apart and seen the destruction Ethanol does if left over the winter or longer. There is a reson they only sell non Ethanol at marinas. Take a junk carb and fill the bowl wth Ethanol then put it away somewhere safe for 4 to 6 months and pull it apart. I think you will be amazed. Exhaust is another isue. Did you ever notice all the water trickeling out of the car in front of yous tail pipe at the stoplight ? That a result of Ethanol and is a major polution going down the storm drains. It also causes you exaust to rot out much sooner. There are many articles writen about the good and bad effects of Ethanol over the years and I choose not to run it in my vintage or small engines. Tim
pistonbroke is offline   Reply With Quote
Old 01-11-2026, 10:48 AM   #11
cas3
I run any any old pump gas all summer, but I do try to buy pure gas on the last few fill ups before winter. Never use ethanol in the chain saws.
Old 01-11-2026, 11:42 AM   #12
totto
totto's Avatar
I run "recreation fuel"(no ethanol) in my '34 and '57 and I have no fuel problems. Fuel is more $$ but vehicles run GREAT. Get that "corn " out of the fuel!!!
totto is offline   Reply With Quote
Old 01-11-2026, 11:47 AM   #13
19Fordy
19Fordy's Avatar
Where does one buy "recreation fuel"?
Old 01-11-2026, 11:59 AM   #14
kurt v
I'M in sc most gas stations sell it at the pumps along with the other junk.
kurt v is offline   Reply With Quote
Old 01-11-2026, 12:00 PM   #15
Scotty's 52 F3
Scotty's 52 F3's Avatar
My old engines run fine on ethanol until the summer heat hits. I can see the gas boiling in the sight glasses and fuel pump bowls. It doesn't happen with non ethanol.
I've had people tell me it's bull, but my carbureted vehicles stall in traffic and won't restart when the summer temps hit and yet they run all season without trouble when they have non ethanol. They are not overheating either. Same for my daughter's 66 Mustang. She quit driving it in the summer. Now we have non ethanol gas locally and that's what we run for our carbureted engines.
Both ethanol and non ethanol turn to crud after sitting in fuel bowls if your engine isn't run in a long time, but ethanol gas sure does some damage. Major corrosion. Non ethanol crud is more like varnish and cleans up with carb cleaner.
So as long as I have non ethanol gas available for my old carbureted engines, I will run it.
Scotty's 52 F3 is offline   Reply With Quote
Old 01-11-2026, 02:36 PM   #16
mcgarrett
I believe all Buc-ees locations sell it...pure gasoline; no ethanol.
mcgarrett is offline   Reply With Quote
Old 01-11-2026, 03:41 PM   #17
flatford8
flatford8's Avatar
I’m fortunate to have Non-ethanol at a couple of places close to me. All I run in my ‘50…..Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver…RIP
Old 01-11-2026, 04:36 PM   #18
FortyNiner
FortyNiner's Avatar
It will vary by local practice but outdoor power users - boaters and off road equipment in particular - is a good place to start.
19 and 49 F1 - jes' like Henry II built
1946 Deluxe - as Henry built it
FortyNiner is offline   Reply With Quote
Old 01-11-2026, 05:30 PM   #19
ford38v8
ford38v8's Avatar
Thanks all!
#4 - tank to firewall fuel line (rust-out)
#5 - fiber fuel pump valves (sticky)
#6 - fiber carb needle valves (sticky)
#7 - 4 oz of Stabyl Marine in every tank (puts a layer of oil atop the fuel to prevent absorption of moisture)
Alan
ford38v8 is online now   Reply With Quote
Old 01-11-2026, 11:26 PM   #20
hueyhoolihan
our local marina sells non-ethanol ga$ to the public. you can drive to the Marina. no need to sail in or anything. just bring your 10 gallon can, walk into the harbor masters office and tell them you want some gasoline. a pleasant maintenance man will soon arrive and take you to the pumps and you can buy as much gas as you want at about 5-6 bucks a gallon.
