Old 01-05-2026, 12:58 AM   #1
FlatheadEric
FlatheadEric's Avatar
Default 1940 Pickup Panel Parts
A friend imported a deceased estate USA 1940 pickup into NZ that had been fitted out with 1968 Mustang engine and running gear, along with big and small fat wheels and tyres. It came with left over bits and pieces from its original 1940 pickup origin.
We have not been able to identify the two body panels in the photos. There is a left and right of both panels. The one with the criss-cross swage is made of fairly heavy gauge sheet steel.
Do these belong to an original 1940-41 pickup that are now surplus after the Mustang running gear and fat wheels were fitted?
Thanks for any help in identifying these parts.
FlatheadEric is offline   Reply With Quote
Old 01-05-2026, 03:37 AM   #2
Mart
Mart's Avatar
Default Re: 1940 Pickup Panel Parts
The square-ish ones are gravel deflectors that fit in the front fenders behind the front wheels. The long crescent shaped pieces fit between the grille and fenders to help channel air towards the radiator.
Mart.
Old 01-05-2026, 11:24 AM   #3
petehoovie
petehoovie's Avatar
Old 01-05-2026, 11:59 AM   #4
FlatheadEric
Thanks for that Mart, I was hoping you would see this post as I have seen your original pickup on here quite a bit in the past.
