Old 01-01-2026, 07:45 PM   #1
slopokpete
Default 59AB Distributer Confusion
I am in the process of swapping engines (both 59AB) in my early 1947 Ford. This is fairly original car with a lot of miles on the odometer.
Several years ago I had the distributer from my original engine rebuilt and a Pertronix installed.
It is the crab style with a one piece cap with the wires coming out the side of the cap.
My donor engine (from a 46 or 47) was also from a fairly original car with much lower miles.
This engine has the two piece cap style distributer.
My plan was to just swap distributers. These are both two bolt distributors.
Here's the reason for this post.
The back of the distributers are different. The crab distributor extends farther and the end of the cam is farther in from the face of the cover. You can see the difference in the depth of the distributers when holding them side by side.
So is there a solution that will allow me to swap these?
Thanks
slopokpete is offline   Reply With Quote
Old 01-01-2026, 07:54 PM   #2
big deuce
big deuce's Avatar
Default Re: 59AB Distributer Confusion
https://vintageautogarage.com/ford-f...jzJOyAUkWF4mUY
big deuce is offline   Reply With Quote
Old 01-01-2026, 08:08 PM   #3
slopokpete
My dilemma is trying to fit the crab style distributer (deeper on the back) to the engine that had the two piece cap style ( shorter on the back).
Is it possible that my donor engine has one of these adapters from the factory?
Old 01-01-2026, 08:20 PM   #4
big deuce
big deuce's Avatar
Can you post pics of the two distributors? I wouldn't think there is an adapter from the factory, possibly the cam with the longer nose. May need to space the distributor out if your cam nose is long.
http://www.vanpeltsales.com/FH_web/F...-spacerkit.jpg
Old 01-01-2026, 08:40 PM   #5
Brian
Brian's Avatar
eBay item # 389210121932 is what you'll need
Unfortunately, two half wits don't make a whole wit!
Brian is offline   Reply With Quote
Old 01-02-2026, 12:14 AM   #6
Lawrie
Lawrie's Avatar
and use the one with points.
Lawrie
Lawrie is offline   Reply With Quote
Old 01-02-2026, 01:06 PM   #7
rotorwrench
rotorwrench's Avatar
The crab type was developed for the 1942 model Year which was short lived in that the US became involved in the war and shut down auto production in February of 1942. During the war, a more sealed design was developed that became the rabbit ear type distributor with the two piece cap. It was continued in service after the war but it's pretty easy to convert to fit the crab type cap. Some were aluminum and some were cast iron if I remember correctly. During the later 60s and 70s, the rabbit ear type cap components were not available so most folks converted them to the crab type so they could keep the 59 series engines running. Eventually the two piece caps were reproduced as they are today.
The 1941 or 01A distributor was the last of the diver helmet types and the "new" crab for 42 was a one year deal in civilian production. Another thing to watch for is that some were made for the G series 6-cylinder and they are different but similar in appearance. There are adapters available to use 2-bolt types on a 3-bolt cover and there are long cam adapters as well for some aftermarket applications.
Old 01-02-2026, 03:08 PM   #8
Mart
Mart's Avatar
Something needs clarifying here. If both distributors are "crab" type (albeit with different caps) then they should both have long snouts on the back. Different adaptors exist to allow mismatched components to be used.
Look for a spacer to put the distributor about 3/8" forward, and a "button" to extend a short cam. Also look for a 3 to 2 bolt adaptor while you're at it.
Without knowing exactly what you have it is difficult to offer advice.
Many would say use the points and I think I would be one of them.
Mart.
Old 01-02-2026, 04:40 PM   #9
47topless
47topless's Avatar
Give Charlie Schwedler a call. He will tell you exactly what you need and , if you send all your stuff to him for a rebuild, you will get back a perfect unit.
Charlie NY 716 662 9159
47topless is offline   Reply With Quote
Old 01-03-2026, 12:26 AM   #10
cas3
I've always thought the 2 bolt base was the same, only difference being the rabbit cap and hold down bale VS the crab cap and shorter side clips. never seen a different length cam driver. Has someone been fooling around in there, or is this a stock ford part?
Old 01-03-2026, 12:31 AM   #11
big deuce
big deuce's Avatar
Pete needs to post the pics of the two distributors in question, unless one of his engines has a longer nose came.
Old 01-03-2026, 01:30 PM   #12
slopokpete
One distributor is the crab style and the other is a rabbit ear style. I am trying to install the crab style distributor on the engine that originally had the rabbit ear style and it was proud of the cover.
Two members pointed me to the adapter that will solve my dilemma!
I want to thank the members that provided help and guidance as well as an education on why there were two different style of distributors used on these engines.
