Old 12-19-2025, 12:26 AM   #1
my4dv8
Default 32 b4 cragar head timing gear
Have been trying to get a good link to specialty motor cams but so far have come up empty. The 1932 B 4 with a cragar OHv conversion, a scat crank and scat rods etc after not even being run in like 400 miles or less. Developed a Donka donka noise , I thought small end knock . Upon pulling it down found the timing gear had excessive back lash and the weird coating was coming off and going through things. Plus two lifters not rotating, maybe a poorly ground local cam with little or no taper on two lobes. Haven’t got the crank out yet.
But a good contact for stipe would be a great start.
my4dv8 is offline   Reply With Quote
Old 12-19-2025, 02:05 AM   #2
petehoovie
petehoovie's Avatar
Default Re: 32 b4 cragar head timing gear
Old 12-19-2025, 11:24 AM   #3
Bob C
See post 20 in the link for some info on Specialty Motor Cams.
https://www.fordbarn.com/forum/showt...ght=bill+stipe
Old 12-19-2025, 09:16 PM   #4
Brian
Brian's Avatar
Are oversize cam gears available for the bangers? I know they are for V8's.
Unfortunately, two half wits don't make a whole wit!
Brian is offline   Reply With Quote
Old 12-19-2025, 10:31 PM   #5
Hitman
400 miles is too early to tell. The tooth wear looks fine, so no line boring related issues. However those usually take many more miles to develop.
Aluminum cam gears are well known to make noise. Mines been in for tens of thousands of miles, and most think I have a rod knock. I don’t.
Hitman is offline   Reply With Quote
Old 12-19-2025, 11:09 PM   #6
Newc
Newc's Avatar
Charley Yapp -SSOS 4 cyl guys for over 25 yrs. the go to place. Newc
Old 12-20-2025, 05:41 PM   #7
Bruce of MN
Bruce of MN's Avatar
SOSS
https://www.secretsofspeed.com/soss-index
Bruce of MN is online now   Reply With Quote
Old 12-25-2025, 08:26 AM   #8
Randall
Randall's Avatar
contact Dan Mceachern he makes over and undersize gears
Randall is offline   Reply With Quote
Old 12-25-2025, 01:29 PM   #9
alchemy
alchemy's Avatar
Wouldn’t the oversize or undersized gear be needed if it was align bored?
alchemy is offline   Reply With Quote
