Old 12-13-2025, 03:40 PM   #1
jerrytocci
Default Vented gas cap
How do I tell if my gas cap is vented.
jerrytocci is offline   Reply With Quote
Old 12-13-2025, 03:54 PM   #2
1955cj5
1955cj5's Avatar
Default Re: Vented gas cap
This is the early style for the tank with a threaded filler neck.
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
Old 12-13-2025, 04:24 PM   #3
Stew Masche
Stew Masche's Avatar
30-31 style has this type of venting.
Always one bad decision away from a good time.
Stew Masche is offline   Reply With Quote
Old 12-14-2025, 11:47 AM   #4
Will N
Will N's Avatar
And, if it wasn't vented, your car wouldn't run more that a minute or two before it stalled from gas starvation. The gas leaving the tank flowing into the carb bowl would create a vacuum, and when that vacuum was strong enough the gas would stop flowing.
Will N is offline   Reply With Quote
Old 12-15-2025, 07:04 AM   #5
chap52
chap52's Avatar
Had that vented cap plug up on a drive one day and was about 20 miles from my destination. Car sputtered to a halt! Remembered what I had read about this potential issue and loosened the fuel cap and heart the tell-tale whoosh as air rushed into the tank.
Left the cap loose, drove to my destination and then the 40 miles back home with a loose cap, but no issues.
I ended up drilling a couple of extra vent holes in the cap. Never had the problem again. Chap
chap52 is offline   Reply With Quote
