Old 12-05-2025, 01:24 PM   #1
Henry Ford IV
Default Torque Tube Connection to Transmission
I hope the pictures posted. This is the connection of the torque tube to the transmission, looking up at it. There is a space between them. The bolts will not snug down, and, I am afraid to really go after them because the whole bolt seems to move, as if it will come loose? What is going on here? Can I leave it as is? The prior owner had it frame off, engine and trans and rear out.
Henry Ford IV is offline   Reply With Quote
Old 12-05-2025, 01:24 PM   #2
petehoovie
petehoovie's Avatar
Default Re: Torque Tube Connection to Transmission
Old 12-05-2025, 02:04 PM   #3
cdan34
cdan34's Avatar
It's possible the threads on stud or transmission are stripped. So to find out you turn and tighten nut. If stripped it must come out and there are various thread repair kits. If ok, Christmas came early !
Good Luck
cdan34 is offline   Reply With Quote
Old 12-05-2025, 02:09 PM   #4
cdan34
cdan34's Avatar
Good Luck
Old 12-05-2025, 02:14 PM   #5
cdan34
cdan34's Avatar
I could be wrong maybe those studs, bolts didn't go in transmission, but the adapter. Could be a bigger problem. Help please !!
Old 12-05-2025, 02:56 PM   #6
34fordy
34fordy's Avatar
Those bolts should have a D head that keeps them from turning.
34fordy is online now   Reply With Quote
Old 12-05-2025, 06:59 PM   #7
Kube
Super Moderator
Kube's Avatar
It appears the rear transmission mount is well beyond its life expectancy. I am certain the rectangular heads of those bolts are simply spinning within the old / soft rubber. There is no way to get in there to hold them.
Time to replace that mount.
By the way, get one while you still can. They will not be reproduced again and when they are gone, well, you will be up sh--- creek.
Mike Driskell sells a quality reproduction at a fair price.
Old 12-05-2025, 07:17 PM   #8
alchemy
alchemy's Avatar
Is the inner cone in there? Looks like a 33-34, correct?
alchemy is offline   Reply With Quote
Old 12-05-2025, 07:45 PM   #9
Henry Ford IV
I see that mount on that website. It is $290! Correct? And that is 100% the problem? Will the transmission leak as is?
Old 12-05-2025, 07:45 PM   #10
Henry Ford IV
No, it is a 35.
Old 12-05-2025, 07:57 PM   #11
34fordy
34fordy's Avatar
I can't help but wonder if whoever threw this back together used ordinary fasteners. That might be why you cannot tighten them.
Old 12-05-2025, 08:04 PM   #12
34fordy
34fordy's Avatar
Correct bolts from 3rd Gen
Old 12-05-2025, 08:15 PM   #13
34fordy
34fordy's Avatar
This is an inside look. If the rubber mount has disintegrated the D head bolts could turn when tightening.
I just stuck the bolts in for the picture. I see two are in backwards lol.
Old 12-05-2025, 09:57 PM   #14
petehoovie
petehoovie's Avatar
Old 12-05-2025, 09:58 PM   #15
petehoovie
petehoovie's Avatar
Old 12-06-2025, 03:52 AM   #16
19Fordy
19Fordy's Avatar
I wonder if there is any way a 1940-48 transmission mount could be adapted to fit your car. The bolt set up is more accessable.
Old 12-06-2025, 06:24 AM   #17
Mac VP
Mac VP's Avatar
He said that he has a 1935 Ford. The rear support (which also incorporates the rubber vibration ring) has the flange on the one side for mounting the parking brake lever. I don’t know how he’d be able to mount the lever to any of the 1937-48 rear support castings. He’d be smart to replace the 48-5089 rear support with a new one.
His photos suggest that the retaining nuts are not secured properly…..one looks ready to find its way to the road. I can’t remember if Ford used lock washers under the four nuts but they should be secured better. Locking nuts or slotted nuts with safety wire would keep the OP sleeping better at night.
As Kube points out, the “L” head shape of the four bolts is designed to sit in the slots molded into the rubber ring. His old rubber isolator has passed its expiration date I believe.
VANPELT SALES LLC
Cincinnati, Ohio
Office: 513-724-9486
www.vanpeltsales.com
www.classictransmission.com
Mac VP is offline   Reply With Quote
Old 12-06-2025, 06:35 AM   #18
Tim Ayers
Ugh. I believe Sacramento Vintage Ford will revulcanize an original one, but they get $75 per. Thanks for the heads up. I'll pick one up from Third Gen to have in stock.
Old 12-06-2025, 06:59 AM   #19
Henry Ford IV
This is all great stuff, thanks to everyone. I will disassemble and see what I need.
Old 12-06-2025, 07:37 AM   #20
Model51
Model51's Avatar
My advice is to buy reproduction parts you need now while you still can. Sources of reproduction parts are drying up fast and there's no good way to predict when or if things will no longer be obtainable.
1935 157" 1 1/2 ton stake truck undergoing full original restoration
1936 131 1/2" panel truck rescue preservation
Author of the 1935-1936 Ford Model 51 V8 Truck book published by the Early Ford V8 Club of America
Model51 is offline   Reply With Quote
