Old 12-03-2025, 07:30 PM   #1
V8guy
V8guy's Avatar
Default JB Weld on a fuel syste, repair
Planning on doing a repair on my 1935 hydrostatic fuel gauge sender over this winter. Will the fuel soften the JB Weld if submerged in fuel tank has anyone used it for ruel system repairs ??
V8guy is offline   Reply With Quote
Old 12-03-2025, 09:31 PM   #2
Steve51
Steve51's Avatar
Default Re: JB Weld on a fuel syste, repair
It is a common fuel tank repair solution. I used it when the vent tube solder joint started leaking on my Galaxie.
Steve51 is offline   Reply With Quote
Old 12-03-2025, 09:41 PM   #3
farmertom
farmertom's Avatar
v8 guy,there is jb weld on outside bottom of the tank and on filler neck joint on my '37 but dont know about anything about something submerged in fuel. mr. Google might know. Tom.
farmertom is offline   Reply With Quote
Old 12-03-2025, 09:50 PM   #4
paul2748
paul2748's Avatar
Check the product and see if there is some sort of tech line you can call. Or check for a web site that may give you some info.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 12-03-2025, 09:59 PM   #5
hueyhoolihan
drop a glob of it in a container of gas and keep an eye on it for a few weeks?
hueyhoolihan is online now   Reply With Quote
Old 12-03-2025, 11:55 PM   #6
50fordcoupeman
50fordcoupeman's Avatar
JB is an epoxy. Safe for gas repairs in my opinion.
50fordcoupeman is offline   Reply With Quote
Old 12-04-2025, 12:31 AM   #7
Eagle43
I fixed a hole in a gas tank with JB weld. It started leaking again about a year later. Solder works better but be careful.
Eagle43 is offline   Reply With Quote
Old 12-04-2025, 06:03 AM   #8
John Gibson
John Gibson's Avatar
IF you are going to solder or weld a gas tank fill it with exhaust fumes first! Gasoline can’t ignite or burn without oxygen and there isn’t much in the exhaust fumes.
John Gibson is offline   Reply With Quote
Old 12-04-2025, 07:39 AM   #9
glennpm
glennpm's Avatar
Decades ago I watched the repair of a pin hole leak in a gas tank. The area around the hole was cleaned and flux applied. Then the guy heated up a coin held with pliers and melted a blob of solder to it. He immediately pushed it over the pin hole. The solder held and that was all that was needed to make a permanent repair.
Archives of historical but relevant older articles:
Hover mouse over the links below and click!
Rumble Seat’s Notes
Techno Source for the 1932 thru 1953 Flathead Ford
Old 12-04-2025, 08:14 AM   #10
Jack E/NJ
Jack E/NJ's Avatar
TankWeld is a 2-part putty. A bit harder to mix and work with than the cream. But it shouldn't soften as much as the cream when submerged in gasohol.
Jack E/NJ is offline   Reply With Quote
Old 12-04-2025, 08:49 AM   #11
Kube
Super Moderator
Kube's Avatar
Ha! You bring back memories! I have purchased cars with this exact repair. Kind of ingenious...
Old 12-04-2025, 09:41 AM   #12
19Fordy
19Fordy's Avatar
Glenn: I like your "soldered coin" idea. Canadian pennies are still made from copper, unlike the USA.
Old 12-04-2025, 09:57 AM   #13
Kube
Super Moderator
Kube's Avatar
I think many of you guys' lost sight of the fact the original poster is going to repair the sending unit, NOT the tank.
As this repair is being done on the sending unit it would be an easy and quality repair done by soldering. No need to worry about any adverse interactions between a sealer interacting with fuel.
Old 12-04-2025, 10:14 AM   #14
glennpm
glennpm's Avatar
Yes, a great trick and it sure impressed me and it only cost a penny and a bit of solder and flux :-)
Rumble Seat’s Notes
Old 12-04-2025, 02:28 PM   #15
mfirth
I'm with Kube, pull it, solder it, reinstall, done.
mfirth is offline   Reply With Quote
Old 12-04-2025, 02:34 PM   #16
glennpm
glennpm's Avatar
You should be able to repair without pulling the tank.
Rumble Seat’s Notes
Old 12-04-2025, 07:35 PM   #17
Bruce of MN
Bruce of MN's Avatar
I thought Canada dropped pennies ~20 years ago?
Bruce of MN is offline   Reply With Quote
Old 12-05-2025, 10:27 AM   #18
Ziggster
Stopped making pennies in 2012 and the $1 bill in 1989.
Ziggster is offline   Reply With Quote
Old 12-05-2025, 10:59 AM   #19
glennpm
glennpm's Avatar
Note that you don't need to use a copper coin, any will do. The object is to solder the tank pin hole. The hole is tiny with almost no pressure and none for a vented tank other than the fluid head of the gasoline. There is no structural benefit in leaving the coin attached.
Rumble Seat’s Notes
Old 12-05-2025, 11:02 PM   #20
Joe B.
Joe B.'s Avatar
glennpm, Thanks for the valuable archival links.
thread killer
Joe B. is offline   Reply With Quote
