Go Back   The Ford Barn > The Swap Meet > For Sale > Model-A
Old 11-30-2025, 10:25 AM   #1
benbuilder
Default 1928-1931 parts etc
City: Hopkinton
State: MA
Price: Hopkinton
model a ford 1928, 1929, 1930, 1931
64-22998-door bottoms outer patch panels new unused. Macs 1930-1931 coupe
Glass Metal Channel Coupe; Tudor Sedan Most Trucks Right Or Left. 23240 new unused ecklers have 3 new unused cross sill
hundreds of Restorer Magazine and binders will sell all or individual magazines from volume 8- 1963 -volume 52, 2007
wood body cross sill tudor 1930-31
I have a set of frame rails that were cut off at the rear, good everywhere else for a z frame
1928/1929 cowl sides
1928 1929 TAnk-leaks but looks perfect
sub rail extension 1928 1929
sub rail extension wood blocks 28-29
a pillars lower 28-2+9
tudor window regulator
1931 engine and transmission running - have video
Tudor/truck door window glass - one piece
19" rims. need sandblasting
I have a front end complete or in parts
i have a rear end complete
Ford Model A Carburetor Tillotson, not warped, looks ready to go
brake parts
many frame parts
entire engine for sale, have not tried to start it A2139573 1929
rear axle,
gas gauge tools
good radiator
STEWART WARNER SPEEDOMETER DECAL NEW UNUSED-ORDERED WRONG PART NUMBER
headlight rim rings
12 volt model a conversion headlights
Model A Ford Gear Shift Lever Plate Floor Boards Shifter
pass rear bumper bracket
model a front axle
front bumper
pass side frame horn
motor mounts
other small stuff
brakes backing plates etc.
All Below new from Brattons:
Side Mount Bracket Bolts for Model A Ford
GENERATOR COVER BAND, PART #: 15400
zenith carb gasket set
RIM LINER FOR 19 OR 21 WHEELS, PART #: 1120
30 - 31 STAINLESS SHOW HUB CAP WITH STEEL LINER, PART #: 1470
RUNNING BOARD BRACKET BOLTS, PART #: 6740
BATTERY HOLD DOWN FRAME, PART #: 6880
Side Mount Bracket Bolts, cross drilled bolts & 3 castle nuts to mount the spare tire bracket to the frame
30 - 31 RADIATOR SHELL GROMMETS, PART #: 11860
Heavy felt pad fits tightly around the steering column & the pedals when used with A35122S.-- floor board pedal plate felt pad
benbuilder is offline   Reply With Quote
Old 01-17-2026, 11:19 AM   #2
benbuilder
Default Re: 1928-1931 parts etc
adding some pictures
