#1 |
i have an open end wrench that i do not know when it is from. it is 9/16 and 5/8. the thing i have not seen before is the ford script is very large, 5/8 inch. i ain't never seen one before, does anybody know what year it might be?
#2 |
It's likely from the model T era. They did use larger script back then.
#3 |
I forgets: What size is the ForD Socket: 23/36?" Fits on bearing nut?
#4 |
If you’re speaking of the nut on the connecting rod crankshaft journal, I’ve seen them 19/32” (usually original) and 5/8” (usually replacement), and I’ve heard that there are some 21/32” but I’ve not seen one. As others have pointed out, 19/32” is close enough that 15 mm works.
JayJay San Francisco Bay Area ------------------------ 1930 Murray Town Sedan (under reconstruction) 1931 Briggs S/W Town Sedan It isn't a defect, it's a feature! |
#5 |
21/32 would be the standard Model A connection rod nut size and would have been a standard socket or wrench in most sets for a lot of years.
