Old 11-13-2025, 12:11 PM   #1
Thomas Sargent
Thomas Sargent's Avatar
Default power brakes for 40 ford
I have installed a dual cylinder master cylinder 1" bore on my 1940 ford. (from early Mustang I am told) I have also installed Bendix style brakes on all four corners. 2" wide shoes. I would like to know if anyone has done similar and also installed a power booster. I have 18" vac at idle. engine is flathead, any input would be appreciated.
Thomas Sargent is offline   Reply With Quote
Old 11-13-2025, 12:20 PM   #2
Thomas Sargent
Default Re: power brakes for 40 ford
Here is a pix of my master cyl
Old 11-13-2025, 12:23 PM   #3
petehoovie
petehoovie's Avatar
Old 11-13-2025, 12:43 PM   #4
john in illinois
john in illinois's Avatar
I have the same brake parts on my model A Tudor with 16" wheels. I have driven it many miles including through the rocky mtn. passes and never felt the need for a booster.
I also have Boling Brothers Bendix brakes and Mustang master cylinder. on my AV8 roadster.
John
Welcome each day
john in illinois is offline   Reply With Quote
Old 11-13-2025, 01:08 PM   #5
rich b
rich b's Avatar
If you are capable, you could fabricate a bracket and mount a small dual diaphragm booster and master cylinder farther to the rear where the area between the frame rail and X rail is wider; then operate it with a longer push rod (for strength, I usually use DOM tube for long pushrods).
Another way (like back to the '70s) is a single master along with a hydrovac booster.
rich b is offline   Reply With Quote
Old 11-13-2025, 03:02 PM   #6
glennpm
glennpm's Avatar
I have had a Midland Hy-Power Booster aka Hydrovac on my '40 for years with a single chamber master cylinder. It is excellent with disk brakes in front. Note that these boosters make pedal effort easier. If you have a low pedal arm ratio, you can benefit by using a larger diameter master cylinder bore such as used on disk brake applications. This will give you more volume per stroke inch and also give less pedal effort with a booster.
I went through two originals and now have a rebuilt one done by Ed Strain whom I recommend, https://brakeboosterrebuild.com/rebuilds/
This is my post on the Midland unit. https://www.fordbarn.com/forum/showp...8&postcount=10 Read the whole thread.
There are also dual remotes for dual pot master cylinders. Note that 70% of braking is from the front only. For my '32 but what I have now with a stepped bore master cylinder works very well, but hey, another unnecessary Winter project for me :-) Here is a link to previous discussion, https://www.fordbarn.com/forum/showt...pped&showall=1 If I do boost my '32 braking, I would just use it for the front drums.
Here is a pricey dual remote, https://mpbrakes.com/product/bs1011k...brake-booster/
A couple of threads from the HAMB
https://www.jalopyjournal.com/forum/...sters.1216131/
https://www.jalopyjournal.com/forum/...units.1002886/
Archives of historical but relevant older articles:
Hover mouse over the links below and click!
Rumble Seat’s Notes
Techno Source for the 1932 thru 1953 Flathead Ford
Old 11-14-2025, 09:18 AM   #7
V8 Bob
V8 Bob's Avatar
Why do you think you need a booster?
I would caution the use of power assist with 4 wheel Bendix style servo drum brakes on low to mid-weight vehicles, like your '40, because touchy heavy braking and/or erratic handling can result, especially if the stock non-power pedal ratio has not been reduced for power assist, imo.
Keep in mind many vehicles in this weight class came from the factory with manual drum/drum and some disc/drum brakes until the mid-late '70s when power disc/drum became the norm.
JFYI, I run manual 1' dual masters on my disc/drum '32,'40, and drum/drum '51 with no issues.
V8 Bob is offline   Reply With Quote
