Old 11-09-2025, 10:40 AM   #1
Afordman31
Afordman31's Avatar
Default Checking spare Distributor
Retarding the spark when starting engine was fine but when I went over half the travel advancing the spark the engine wanted to cut out. Any suggestions to the problem?
Afordman31 is offline   Reply With Quote
Old 11-09-2025, 11:08 AM   #2
johnbuckley
johnbuckley's Avatar
Default Re: Checking spare Distributor
I'd suspect soemthing shorting ... possibly the pigtail wire under the plate.
johnbuckley is offline   Reply With Quote
Old 11-09-2025, 11:15 AM   #3
nkaminar
nkaminar's Avatar
Check to see if the top plate is not closing up the points in the advanced condition or if the wire going from the top plate to the bottom plate is not shorting out when the top plate is in the advanced position. Another possibility is the arm for the moving points shorting out. Just carefully examine what changes when you advance the timing including using your multimeter. The top plate should not be loose in the distributor so that it's center moves when advancing the timing.
Old 11-09-2025, 12:01 PM   #4
Bob C
Make sure the flag terminal has the correct bend in it.
Old 11-09-2025, 01:24 PM   #5
Marshall V. Daut
Also ensure that the spark rod from the steering column to the distributor isn't rubbing against something metal in its travel, killing the ignition. If for some reason the armored ignition cable is "hot" and the rod touches metal, that will kill the ignition until you move the spark lever and change the position of the rod.
But I agree with the others that the problem most likely is the wire connecting the lower plate to the upper plate, whose flag is touching the metal distributor body and shorting out the ignition. A very common problem. The wire Ford used originally is WAY too thick, stiff and short for the job it has to perform. A longer, smaller gauge wire that is flexible would have been a far better choice and would have saved millions of owners a ton of electrical headaches over the past 97 years!
Marshall
