Old 10-28-2025, 07:32 AM   #1
rockfla
rockfla's Avatar
Default Is there a difference and IF so, what
Anyone know IF there is a difference between 1933 & 34 headlight support bases and 1935 & 36 Truck headlight support bases?? IF so....could you share how to tell?
Old 10-28-2025, 02:50 PM   #2
Karl Wescott
Karl Wescott's Avatar
Default Re: Is there a difference and IF so, what
Yes they are different. The shape of the fender is slightly different between them. The visual way to tell the difference is the angle of the square hole for the mount bolt... However right now I cannot remember which is which. Also the pickup one is 1935-37, and there is a big truck one which is shortened (I have seen pix, but not touched one)
Karl Wescott is offline   Reply With Quote
Old 10-28-2025, 05:17 PM   #3
Karl Wescott
The brackets are different
Oops on the rotation of the square hole... they are the same rotation 1933-34 Pass vs 1935-37 PU.
Photo attached. When placed on a flat surface and viewed from directly above the edge of the 1933-34 Passenger headlight mount will be about even with the edge of the bracket, on the 1935-37 Pickup bracket it will overhang a bit.
File Type: jpg HeadlghtStandComparison1933-34vs1935-37PU.jpg (29.6 KB, 206 views)
Old 10-28-2025, 05:45 PM   #4
petehoovie
petehoovie's Avatar
Old 10-29-2025, 08:44 AM   #5
oldandtired
I have had several pairs of the shorter headlight stands. Ford made a spacer so that the headlights would work with the shorter stands and the regular length headlight mount. I have a couple of pairs of the spacers but no longer have any of the shorter stands.
oldandtired is offline   Reply With Quote
Old 10-29-2025, 10:29 AM   #6
rockfla
rockfla's Avatar
Karl
Thank you for the response and picture, SO....IF I am understanding it all, the Truck stands have more of a "flared falnge" than the 33-34 stands?
Thank you once again
Rockfla
Old 10-29-2025, 11:44 AM   #7
DavidG
DavidG's Avatar
The '33-'34 versions are slightly higheer, top to bottom.
Old 10-29-2025, 12:34 PM   #8
rockfla
rockfla's Avatar
Thank you very much David.
