Old 10-10-2025, 06:43 PM   #1
[email protected]
johnr9q@yahoo.com's Avatar
Default Degreaser
For nuts and bolts, what do you recommend?
johnr9q@yahoo.com is offline   Reply With Quote
Old 10-11-2025, 06:42 AM   #2
Keith
Default Re: Degreaser
I use Simple Green close to full strength and in old and hard crusted green I boil in the solution.
Keith
Keith is offline   Reply With Quote
Old 10-11-2025, 07:00 AM   #3
nkaminar
nkaminar's Avatar
Use the dishwasher. But only when your wife is not home.
Old 10-11-2025, 07:35 AM   #4
Merc Cruzer
Merc Cruzer's Avatar
I have used the Harbor Freight degreaser for years and like it.
Merc Cruzer is offline   Reply With Quote
Old 10-11-2025, 08:19 AM   #5
rackops
rackops's Avatar
I've tried everything that I can buy locally, and the best I've ever used is gasoline.
Yes, I know, it's dangerous and has all sorts of other bad things (used to be a fuels safety officer in the military). But, it works really well. A little goes a long way and it can be used many times before it's no longer usable.
Using an old toothbrush and a mason jar of gas, along with a sacrificial baking dish, you can easily remove all the gunk off many nuts and bolts. Follow up with a good degreaser to remove the gasoline residue once clean.
Always wear PPE. Don't smoke while cleaning parts. Don't use the mason jar for food. Don't use the toothbrush for brushing teeth. Don't bake anything in the baking dish. Don't get it on your skin or in your eyes. Always properly dispose of any unusuable product. Don't allow it to atomize. Don't eat afterward until properly washing. Don't drink it. Don't wear good clothes. And other common-sense things as caveats.
Member, MARC
Current owner, 1928 RHD Australian-built Phaeton CA4752 "Felicity"
Former owner, 1931 Victoria, 1929 Phaeton, 1929 Fordor
rackops is offline   Reply With Quote
Old 10-11-2025, 09:48 AM   #6
katy
katy's Avatar
I use the old standby, stoddard solvent. aka varsol and various other names.
Old 10-11-2025, 10:03 AM   #7
Big hammer
Recycle plastic coffee can and soak, give it a shake now and then, simple green or E-85 as it has 51-85 % ethanol using the safety advice in post #5
get a bigger hammer tap done
Old 10-12-2025, 04:12 AM   #8
ndnchf
ndnchf's Avatar
I've been using kerosene for 35 years. It works great, is safe and readilly available.
Restored Ford 6 & 12 volt generators
ndnchf is offline   Reply With Quote
Old 10-12-2025, 07:59 AM   #9
Bob Bidonde
Bob Bidonde's Avatar
I have been using Dawn detergent, lacquer thinner, acetone, gasoline, kerosene & Gunk.
Bob Bidonde
Bob Bidonde is online now   Reply With Quote
Old 10-12-2025, 09:20 AM   #10
katy
katy's Avatar
That's quite a mixture, are they all equal portions?
Old 10-12-2025, 11:06 AM   #11
Big hammer
Katy LOL ��
Old 10-12-2025, 02:03 PM   #12
Klattu1929
Diesel/Gasoline (50-50), acetone, brake Kleen, carb cleaner-1 gallon immersion with the basket, simple green.
Klattu1929 is offline   Reply With Quote
Old 10-13-2025, 06:35 AM   #13
1crosscut
1crosscut's Avatar
Automotive parts stores carry a carburetor/parts cleaner in a one gallon can that has a parts basket with a handle inside of the can. Works great for soaking and cleaning bolts, nuts, small bits and pieces etc...
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 10-14-2025, 08:54 AM   #14
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Harbor Freight and Vevor offer inexpensive ultrasonic cleaners that can heat the detergent too. Around here we have a nice degreaser called Simply Awesome that is available at the dollar stores.
If you have a larger item that you need to clean, most of the quality foaming Oven Cleaners that come in an aerosol can do pretty decent and dissolving grease/sludge. Flush wih water afterwards.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 10-14-2025, 08:58 AM   #15
Canton_Model_A's
Canton_Model_A's's Avatar
There is this, That is the 1 Gallon can with basket:
https://gunk.com/product/gunk-parts-...p-basket-cc3k/
1929 Model A Tudor - "Darla"
'29 Model A: Old enough to start with a crank, young enough to steal the show!
"Stay away from negative people, they have a problem for every solution"
Model A Ford Club of America
Model A Restorers Club
Motor City A's Club
Canton_Model_A's is offline   Reply With Quote
Old 10-16-2025, 12:20 PM   #16
Tacoma Bob
Tacoma Bob's Avatar
Yup I think its called Totally Awesome out here on the left coast. $1.25 at the Dollar Store as Brent mentions. I usually buy 4-6 quarts at a time. Really good stuff. I have had success with Purple Power too.
Tacoma Bob is offline   Reply With Quote
