Old 10-10-2025, 11:26 AM   #1
34fordy
34fordy's Avatar
Default Columbia question
Is a Columbia 35-36 specific to those 2 years?
34fordy is offline   Reply With Quote
Old 10-10-2025, 11:30 AM   #2
cas3
Default Re: Columbia question
35 & 36 have a unique mount for the radius rods
Old 10-10-2025, 01:49 PM   #3
uncle buck
uncle buck's Avatar
There is also an early and late version with different counts
uncle buck is offline   Reply With Quote
Old 10-11-2025, 12:18 PM   #4
Ken/Alabama
Ken/Alabama's Avatar
The axle housing is the hard part. You could use a 37-41 housing by adding the bracket for the radius rod and cutting off the spring hanger. 35-41 is the same width.
Ken/Alabama is offline   Reply With Quote
Old 10-11-2025, 02:45 PM   #5
deuce5wndw
deuce5wndw's Avatar
Wouldn't a 37-41 be a bolt in as an assembly?
deuce5wndw is offline   Reply With Quote
Old 10-11-2025, 03:16 PM   #6
34fordy
34fordy's Avatar
That is what I was wondering. The "whole kit & caboodle." I think I could use my 36 backing plates and brakes to keep my mechanical brake rods.
Old 10-11-2025, 03:53 PM   #7
Hitman
Yes, they bolt in.
Hitman is offline   Reply With Quote
Old 10-20-2025, 07:59 AM   #8
danliveshere
danliveshere's Avatar
34fordy, yes you could drop a 37-41 in if you changed the radius rods and drive shaft too from a 37 on.
What controls do you have to shift from low to high?
danliveshere is offline   Reply With Quote
Old 10-20-2025, 08:14 AM   #9
34fordy
34fordy's Avatar
Nothing so far.
Old 10-20-2025, 07:50 PM   #10
solidaxle
solidaxle's Avatar
I didn't like the look of mounting the control valve on the cylinder head of my flatty. On my 32, I mounted a 36-37 vacuum control on passenger side of the K member, drilled and tapped the clutch cross shaft to attach a lever rod to activate the main valve. Made a custom cable for the hi/lo shift. Works great and you don't see the control valve. Maybe you could do the same. I also have an original electric control set up that I am not going to use, if you decide to go that way.Whatever you do, you want to make sure there's a way to disable the valve if the clutch is not engaged. This way you will not accidentally damage the unit.
solidaxle is offline   Reply With Quote
Old 10-21-2025, 10:40 AM   #11
cas3
I made mine a manual shift like the Ruxtel in model T's
File Type: jpeg F91622DF-6A45-48B7-8180-68AC500AC901.jpeg (99.7 KB, 163 views)
File Type: jpeg 3F7C1264-6370-4959-954C-9D6448D2447F.jpeg (106.4 KB, 162 views)
File Type: jpeg 7BCB5DBA-C2FA-42A0-B228-751D88FED837.jpeg (135.8 KB, 165 views)
Old 10-21-2025, 11:09 AM   #12
petehoovie
petehoovie's Avatar
Old 10-21-2025, 12:14 PM   #13
tubman
tubman's Avatar
This is one of the few forums I know where you can assume the members know what a Ruckstell is (even when it's misspelled).
Old 10-21-2025, 02:09 PM   #14
glennpm
glennpm's Avatar
I didn't care for it either, I made a bracket to mount the vacuum switch just in front of my steering box, welded a tab to the clutch arm and then fabricated up some 1/4" OD rod; threaded both ends for a clevis one end and the other a connection to the switch. It works super. Love the Columbia!
Archives of historical but relevant older articles:
Hover mouse over the links below and click!
Rumble Seat’s Notes
Techno Source for the 1932 thru 1953 Flathead Ford
Old 10-21-2025, 02:21 PM   #15
solidaxle
solidaxle's Avatar
cas3
Good job making that work. I was highly considering the manual shift like you did, but it just wasn't coming together. Yours looks great.
Old 10-21-2025, 02:48 PM   #16
34fordy
34fordy's Avatar
Hey Clayton, Does your system eliminate all other controls? Is everything accomplished, in and out with the one lever aside your emergency brake lever? Looks like a great job!!!!!!
Old 10-21-2025, 04:15 PM   #17
cas3
Yes, its all done with the hand shift lever. Bad news is you don't get the speedometer correction. I thought it may take some learning to shift it, but no, it shifts just fine like any synchronized transmission.
Old 10-21-2025, 04:16 PM   #18
cas3
And yes Denny, poor spelling! I've had 2 of the model T units over the years and should know better!
Old 10-21-2025, 05:33 PM   #19
tubman
tubman's Avatar
It's not a problem at all (and I didn't mean any disrespect); it's just that i am constantly amazed at the knowledge (both general and specific) possessed by the members here.
Old 10-21-2025, 06:33 PM   #20
cas3
Talking Re: Columbia question
Not a problem here either, just admitting my mistake, and poking you back a little!
Happy motoring.
