#1 |
I can’t find anything on this condenser connected to the oil pressure sender on my ‘35 with a ‘37 engine. I’d prefer to replace it while I’m rewiring the car.
Any ideas on part numbers and/or sources. Not finding anything so far with the usual sources.
'35 5 Window Deluxe Coupe w/radio- wife's uncle purchased new |
#2 |
now that is very unusual,never have seen an ignition condenser hooked up to a oil press. sender. took a second look. i see someone has mounted the condenser with the fuel line hold down but i dont see the condenser wire attached to the sender. Tom.
#3 |
Remove it and toss it. Only purpose was to reduce radio interference from the pulsing sender. And condensers deteriorate over time, even sitting on a shelf. So that one is no use to anyone.
#4 | |
#5 |
That could be it. We have the original bill of sale and it includes the radio as the only option.
#6 |
Curiously. the original invoice (which I also have) shows my car came from the factory without a radio., but it still has the condensers. I figure that the engine assemblies were completed and installed well before the optional accessories were installed, so all of the engines got 'em. |
#7 |
Super Moderator
Winner, winner...chicken dinner.
