Old 09-27-2025, 05:40 PM   #1
Anteek29
Anteek29's Avatar
Default Y Block Fuel Pump
The dual stage fuel pump in my '55 Vic 272 has failed. Who still rebuilds these? My info is that new pumps now come from China and are crap.
Alan
1929 Special Coupe
1941 Pick-Up
1955 Victoria
Anteek29 is offline   Reply With Quote
Old 09-27-2025, 06:14 PM   #2
scicala
scicala's Avatar
Default Re: Y Block Fuel Pump
I agree, China supplies junk fuel pumps.
You can try X Ford Barn member Charlie ny
I know he does fuel pumps too, as well as carburetors ect
Charlie Schwendler
(716) 662-9159
[email protected]
Old 09-27-2025, 06:31 PM   #3
dmsfrr
dmsfrr's Avatar
Originally Posted by Anteek29 View Post
. . . My info is that new pumps now come from China and are crap.
Fyi, there are no US manufacturers of that style new replacement fuel pump. All new parts suppliers are selling the defective chinesium clones. (for the last 5+ yrs, you'd think they'd have it figured out by now)
Below: these folks rebuilt a couple older dual action pumps for me. 6 months & approx 1000 miles now and still working fine.
dmsfrr is offline   Reply With Quote
Old 09-27-2025, 07:32 PM   #4
paul2748
paul2748's Avatar
AG Rebuilders is another rebuilder of pumps. They have done a couple of them for me with no problems
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 09-27-2025, 07:37 PM   #5
paul2748
paul2748's Avatar
If you are interested in a spare pump for your 55, I have one but s/b rebuilt
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 09-28-2025, 09:44 AM   #6
Anteek29
Anteek29's Avatar
Many thanks, fellas! I'll follow up on your suggestions.
Alan
1929 Special Coupe
1941 Pick-Up
1955 Victoria
Old 09-28-2025, 07:08 PM   #7
10gaugemag
Tagged.
10gaugemag is offline   Reply With Quote
Old 09-29-2025, 09:13 AM   #8
Bleach
Bleach's Avatar
Good thing I have a spare plus an NOS pump. The OEM pumps look easy to rebuild if good parts are available.
1956 Ford Fairlane Town Sedan 292 V8 with Ford-o-Matic
Bleach is offline   Reply With Quote
Old 09-30-2025, 09:05 PM   #9
Anteek29
Anteek29's Avatar
Had a conversation today with Charlie NY about rebuilding my fuel pump. I described mine and he said it was likely made in China and is not rebuildable. I sent photos for confirmation.
Alan
1929 Special Coupe
1941 Pick-Up
1955 Victoria
Old 09-30-2025, 10:45 PM   #10
dmsfrr
dmsfrr's Avatar
The chinese fuel pumps can usually be spotted by having Phillips head screws.
Old 10-01-2025, 01:23 PM   #11
dmsfrr
dmsfrr's Avatar
Anteek29, here's where I got the info about fuel pumps with Phillips head screws... It mentions old original style pumps with hex head and flat slot screws are ok.
This attached article was published in the Spring of '21, almost a year after the defective off-shore fuel pumps were first noticed.
AFAIK the 'new/corrected' non-Airtex fuel pumps mentioned in the article never materialized.
I've seen many comments in Y-block and '55/'57 T-bird groups about the poor build quality of chinese replacement fuel pumps and they are as Charlie NY mentioned, not rebuildable.
Old 10-04-2025, 11:17 PM   #12
Jim.UT
Jim.UT's Avatar
After reading the responses to this inquiry I went out to my 55 and checked. Slotted screws and "Made in U.S.A." cast into the top.
I also looked on ebay to see what OEM pumps might be out there just in case I need one down the road. I see some with a glass sediment bowl on the bottom and some without. The one on my car does not have one. Which is correct for 55? Seems like a glass bowl hanging down that low might be susceptible to rocks tossed up by the tires.
Jim.UT is offline   Reply With Quote
Old 10-05-2025, 06:27 PM   #13
41Fordor
41Fordor's Avatar
Then and now has a good selection.
My 54 Y-block has the sediment bowl on top and the dual diaphragm for wipers.
https://www.then-now-auto.com/produc...uel-pump-kits/
41Fordor is offline   Reply With Quote
Old 10-05-2025, 07:30 PM   #14
paul2748
paul2748's Avatar
Combo pumps - 54 Fuel pumps are one of a kind and the only YBlock pump that I am aware of that had the filter on top. All the rest had the filter on the bottom (with some exceptions that I ran across). TBird pumps did not have a filter as part of the pump.
The pumps w/o the vacuum assist are different and I have no idea about them.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 10-06-2025, 08:52 AM   #15
Jim.UT
Jim.UT's Avatar
Mine has the vacuum assist and no glass bulb on the bottom. There is an in line filter upstream from the pump (clear plastic) that lays horizontally along the bottom of the inner fender.
Sounds like I have a T-bird pump on my Fairlane.
Old 10-06-2025, 01:42 PM   #16
Anteek29
Anteek29's Avatar
Yes, most likely. Same as mine.
Alan
1929 Special Coupe
1941 Pick-Up
1955 Victoria
Old 10-06-2025, 07:07 PM   #17
paul2748
paul2748's Avatar
As I mentioned, there are non-TBird pumps w/o the bottom filter, and In fact I have one. I bought it from some one that had taken it off his 55 sedan as a working pump. I know it is not a TBird pump because the bottom part is different and the in/out ports are reversed or have a different orientation than a Tbird pump (don't remember which).
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 10-09-2025, 06:14 PM   #18
10gaugemag
May try to order a rebuild kit from these guys pretty soon. Need to pull mine and see exactly which pump it is first.
