Old 08-28-2025, 06:02 AM   #1
ndnchf
ndnchf's Avatar
Default Help identifying generator mounts
Can someone help identify what these generator mounts go on? Both are 8BA type with similar cast in part numbers, but they are different.
8BA-10153C. This one has the alignment pin fairly close to the center of the bracket. It is also wider looking at it from the side. This one seems to be much more common.
8BA-10153. This one has the alignment pin close to the front edge. Overall the bracket is narrower looking at it from the side.
I restore generators and know them well. But still learning about the different mounts.
What is each one for?
Thanks
Restored Ford 6 & 12 volt generators
ndnchf is offline   Reply With Quote
Old 08-28-2025, 06:31 AM   #2
V8 Bob
V8 Bob's Avatar
Default Re: Help identifying generator mounts
Pretty sure '48 -'53 truck/'49 car wide belt vs '50-'53 car narrow belt brackets.
V8 Bob is offline   Reply With Quote
Old 08-28-2025, 10:53 AM   #3
ndnchf
ndnchf's Avatar
Ok - so which one is for the narrow belt?
Old 08-28-2025, 10:54 AM   #4
petehoovie
petehoovie's Avatar
Thanks
Old 08-30-2025, 07:05 AM   #5
V8 Bob
V8 Bob's Avatar
The mount with the pin close to the center is the narrow belt location, while the one with the pin close to the front edge is for the wide belt.
Old 08-30-2025, 05:34 PM   #6
ndnchf
ndnchf's Avatar
Ok, thanks!
