Old 08-13-2025, 02:46 PM   #1
oldford
Default The rear axle banjo gaskets I ordered are to big
My car is a 32 coupe and the different size shim gaskets that I ordered are to big in diameter. Does the 32 take the model A gaskets, which I assume are smaller.
oldford is offline   Reply With Quote
Old 08-13-2025, 02:54 PM   #2
alchemy
alchemy's Avatar
Default Re: The rear axle banjo gaskets I ordered are to big
You probably have a B rearend. If it’s got a round flange on the front of the banjo housing it’s a B. Scalloped is a V8.
alchemy is offline   Reply With Quote
Old 08-13-2025, 03:25 PM   #3
oldford
Yes it is round. Do you know if the model a gaskets is what i need.
Old 08-13-2025, 04:31 PM   #4
DavidG
DavidG's Avatar
The period chassis parts catalogs, including the inexpensive reprints, indicate that except for the front of the torque tube, the Model B gaskets in question are carryover Model A parts.
Old 08-13-2025, 07:08 PM   #5
oldford
Thanks Dave, I will get them on order.
