Old 08-11-2025, 05:44 PM   #1
drfromnc
Default Grille shell emblem ID
I have a nice reproduction grille shell emblem that doesn’t fit my 34 pickup. It measures about 1 3/4” wide and 7/8” tall. What’s it go on? Thanks
drfromnc is offline   Reply With Quote
Old 08-11-2025, 08:53 PM   #2
petehoovie
petehoovie's Avatar
Default Re: Grille shell emblem ID
Old 08-11-2025, 09:10 PM   #3
big deuce
big deuce's Avatar
Is there a B or 40- number on the back?
big deuce is offline   Reply With Quote
Old 08-11-2025, 09:59 PM   #4
drfromnc
Nope
Old 08-11-2025, 10:09 PM   #5
big deuce
big deuce's Avatar
1932 badge I have here (repro) is 2.200 x 1.100 give or take a frog hair.
Old 08-11-2025, 10:15 PM   #6
nelsb01
nelsb01's Avatar
Does it have a clip or bolt on the back?
nelsb01 is offline   Reply With Quote
Old 08-11-2025, 11:30 PM   #7
deuce lover
deuce lover's Avatar
34 PU uses the same one as 1932.In fact 32-35 Commercial is the same.What is on the back? A clip or a threaded stud? If its a clip it is 35,36 and 38 STD pass car. If its a stud it appears to be 1934 from the shape of the face.33 pass car also has a stud but the curve of it is different.The orig emblems Never had a part number,only the maker like Fox or Ross Ad Seal etc.
Here is an original '32-35 commercial.3rd and 4th pics are of an original '34 pass car.The last 2 pics are of an orig '33 pass car.
If you buy a repro I suggest the Vintique.The reason is Drakes is made to fit HIS bezels SO it will not fit tight in an original bezel.There are slight gaps all the way around.
deuce lover is offline   Reply With Quote
Old 08-12-2025, 07:29 AM   #8
drfromnc
Threaded stud on the back, no numbers or letters on the back either.
Old 08-12-2025, 07:50 AM   #9
deuce lover
Then its a 1934 pass car emblem
Old 08-12-2025, 08:01 AM   #10
drfromnc
Thanks. Just posted pic of back side
Old 08-12-2025, 09:20 AM   #11
deuce lover
Take the nut of and compare the base of the stud and see if matches to a pic of one I sent. The orig 33 has a square base ,34's like 32's are round.Many of the early repros just had a screw soldered on. No originals had part numbers on back,just makers or vendor mark. The correct emblem for your application should be approx 2 1/8 " wide across the front.The 34's approx 1 7/8" or a bit less. Looking at the curve of yours it appears '34 which was more pronounced .35'56 had a curve like the '34 but had a clip on the back.
Old 08-12-2025, 12:10 PM   #12
Newc
Newc's Avatar
found that a tiny O ring makes the best 'lock' washer. Does not stress the solder of the bolt. Newc
Old 08-12-2025, 06:34 PM   #13
drfromnc
Just trying to ID this emblem. I will remove the nut for comparison to your pics.
FYI, I do have an emblem and ornament for my 34 pickup as well as extra ornament.
Thanks
