Old 08-10-2025, 04:24 PM   #1
3twinridges
3twinridges's Avatar
Default Fitting rings question
Fitting the rings in #1 using grant rings on a fresh honed 8BA cylinder. Got the first oil ring fit. When I got to the 2nd oil ring it has a spring inside with directions on joint placement. Tried to compress it and it’s a tight spring! I don’t remember that in the last Hastings rings I used? Is it needed?
JB
3twinridges is offline   Reply With Quote
Old 08-10-2025, 04:59 PM   #2
petehoovie
petehoovie's Avatar
Default Re: Fitting rings question
JB
Old 08-10-2025, 06:04 PM   #3
3twinridges
And for clarity, I am only questioning the spring in the 1st oil ring, not the complete oil ring. Seems like a lot of pressure and added friction.
JB
Old 08-10-2025, 06:53 PM   #4
hueyhoolihan
i have to admit i've never seen nor heard of a spring loaded piston oil ring. but if history proves itself, it's either marketing hype, some kind of cost-cutting move or a combination of both. in any case probably designed to increase profits. and yes, i'm now a full-blown skeptic WRT new products.
apparently you're not the only one having problems getting it...ahem...in the hole. it looks as if a lack of chamfer at the top can be a problem. BTW, they are considered a high performance thing in some modern cars. rings are cheap, i would consider getting something else.
sources for forming an opinion:
https://www.speed-talk.com/forum/viewtopic.php?t=58601
https://forums.jag-lovers.com/t/gran...estions/369221
https://www.mtfca.com/discus/message...tml?1444089078
hueyhoolihan is offline   Reply With Quote
Old 08-10-2025, 06:55 PM   #5
3twinridges
Thank you sir, I have Hastings rings on the way, I am going to just use them.
JB
Old 08-10-2025, 09:53 PM   #6
cadillac512
cadillac512's Avatar
Hi JB. That's a pretty common ring type in heavy duty diesel engines. Yes, the spring is necessary, but I agree with your choice of going with the rings you've ordered. The Hastings 3 pc oil ring is very good. It won't need any fitting or filing.
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'30 Model A Speedster
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
