Old 08-09-2025, 08:47 AM   #1
P.S.
Default How to install a synchronized transmission in a Ford Model A
The full video just published a few minutes ago - https://www.youtube.com/watch?v=BsyCPauO4P0
Gives a great inside look at the Mitchell synchronized transmissions that are built into original Model A transmission cases so you can't tell from casual appearances that the car is modified. Simple bolt-in synchronized transmission with no modifications or cutting needed.
Also- This is the video that the clips are from talking about keeping greasy fingers off the clutch disc, pressure plate, and flywheel surfaces being discussed in another thread.
P.S. is offline   Reply With Quote
