Old 08-04-2025, 08:41 AM   #1
1939Deluxesedan
1939Deluxesedan's Avatar
Default engine question
What is a easy engine to install on my 39 sedan? I don't have a ton of money, and would like to do it on a budget. Just get her running where I can enjoy the car more. It has the original 85hp flathead, and original 3 speed trans. Are there any engines that will bolt to the old trans? I know most folks put a powerhouse V8 in one. I would too, if I had the money, but what is a good economy plan?
Thanks
1939Deluxesedan is offline   Reply With Quote
Old 08-04-2025, 08:55 AM   #2
rockfla
rockfla's Avatar
Default Re: engine question
Thanks
What's wrong with the "original" engine that came in the car? Just a few pieces off the motor sent to a few of "THE guys" here on the Fordbarn for refurbishment/Upgrading AND you will have a very reliable good running "Original" flathead with a fraction of the work required to "replace"/repower your car. What issues are you currently having??
Old 08-04-2025, 09:06 AM   #3
rockfla
rockfla's Avatar
1) take the coil off and send it to: Skip Haney
29436 Taralane Drive
Punta Gorda FL 33982
2) take your distributor off and send it to: Skip Haney
or
Michael Driskell
Third Gen Automotive
2600 Old Nashville Hwy
McMinnville TN 37110
OR
CharlieNY/ Charlie Schwindler
5845 Cole Road
Orchard Park NY 14127
3) Take your carburetor and fuel pump Off and send them to :CharlieNY (above)
After that, you will "most" likely be set for many miles of carefree driving AND joy beyond belief
Old 08-04-2025, 09:15 AM   #4
19Fordy
19Fordy's Avatar
1939DeLuxesedan: Take rockfla advice. Your best bet would be to rebuild or install the same engine that is already in your car. Yes, you can make other engines fit but, that always leads to additional unexpected changes and modifications. KEEP IT SIMPLE by keeping what you already have.
Old 08-04-2025, 10:57 AM   #5
petehoovie
petehoovie's Avatar
Thanks
Old 08-04-2025, 12:13 PM   #6
1939Deluxesedan
When it came to me, the engine was frozen in place. Over time I was able to free it. It spins with the starter now. No fire at the plugs. It needs a distributor. It had a Mallory after market distributor. I believe it has failed. So i need another. If i could get fire, perhaps I could get it to sputter, or even run for a split sec. It needs a carburetor, fuel pump, gas tank and line. One water pump is frozen solid. I would replace both. Likely more. Is the cylinder wall damaged?
This process has the same feel as pulling the handle on one of those "one arm bandits" out in Vegas. But it would be my preference, to restore it. i wish I had the money to send it out and have it professionally rebuilt.
I am exploring my options. Otherwise it will sit out in my barn for more years.
Thanks for the input.
Old 08-04-2025, 12:45 PM   #7
Karl Wescott
Karl Wescott's Avatar
1. You would likely get more money at Vegas.
2. You will likely have much more fun over the years with the car than at Vegas.
3. Before you start throwing parts at it check for compression and do a pressure leak check on the block. Pull the heads and check for hardened valve seats and no cracks. If all looks good the V8 slot has been good to you, if not you may need to spend the $$ to rebuild the block. Drop the pan and CLEAN, CLEAN, CLEAN. Then new oil, of course.
4. Send the water pumps to Skip Haney too.
5. If you are moving forward keep us posted.
Karl Wescott is offline   Reply With Quote
Old 08-04-2025, 01:47 PM   #8
rockfla
rockfla's Avatar
At this point, what you have listed as issues doesn't sound to daunting BUT, can you post a few pictures of the motor so we can see what exactly you have and can better advise you at this point. Getting a distributor, coil, carburetor and fuel pump isn't too difficult and shouldn't be ALL that expensive. I "may"..... have a distributor that I can donate to the cause, I will look at my stash of distributors and see what I can come up with. Lets see what you are currently working with first? In the mean time, I would pour some Marvel Mystery Oil down all the cylinders and down the intake and let that soak in for the next few days!!!!
Old 08-04-2025, 01:56 PM   #9
leon bee
Wondering if you got a way to get the engine out? That's how I like to start.
leon bee is offline   Reply With Quote
Old 08-04-2025, 02:47 PM   #10
19Fordy
19Fordy's Avatar
You might want to contact folks who already have a good running engine for sale. 1940 will fit a 39.
https://www.jalopyjournal.com/forum/...&o=relevance&c[node]=47
Old 08-04-2025, 03:39 PM   #11
Ggmac
Where do you live ? I’ve got 5 very good running flatheads hanging around . Most rebuilt or just re ringed and valve job . I’m in s Florida.
Ggmac is offline   Reply With Quote
Old 08-04-2025, 03:41 PM   #12
1939Deluxesedan
I spent many weeks soaking the rings with marvel mystery oil. That is how I finally got the crank to turn. I would rock it back and forth, taking my time, just a little more each time until I finally got a full rotation. My first hurtle is to get fire to the plugs. I installed new plugs and wires when all this came up.
Old 08-04-2025, 03:44 PM   #13
1939Deluxesedan
I like your thought.
It is hard to put a value on the "cool factor". Riding around with flathead V8 has it in spaded!
Old 08-04-2025, 03:51 PM   #14
Ggmac
I also have many parts that you could try before you drop alot of money on it .
Its fairly easy to remove the intake , just to get an idea of the internal condition. If its decent cyl head removal would be next but not right away . Remove plugs get it cranking easy and check compression. Low is okay at this point .
Dog walk time …
Old 08-04-2025, 04:17 PM   #15
petehoovie
petehoovie's Avatar
Old 08-04-2025, 04:29 PM   #16
mcgarrett
Super neat car! I have a passion for old Ford survivors. It' your car, but I wouldn't do anything to it that would harm its originality; just do what it needs to make run reliably and stop safely. What you have there is a bit of a rare flathead Ford. It's known as aConvertible Sedan and 1939 is the last year they were made; it's also the first year for hydraulic brakes for Ford. To my knowledge there aren't many around. Get with a local Early V8 club chapter and you should be able to recruit some eager club members to help you get it going again. Wish you all the best in getting her back on the road!
mcgarrett is offline   Reply With Quote
Old 08-04-2025, 07:15 PM   #17
19Fordy
19Fordy's Avatar
Ford only made 3561 1939 DeLuxe Convertible Sedans, Model 91A-74.
It still used the 112 in. wheelbase and was 186.33 in. bumper guard to bumper guard.,
Old 08-04-2025, 10:03 PM   #18
Henry Floored
Henry Floored's Avatar
Dog walk time …
Hey I’m in the Tampa bay area and I’m helping a friend with a knock in a 59AB. He might be in the market for a good Flatty. If you’re in the market to se them I’d like to speak to you.
Henry Floored is offline   Reply With Quote
Old 08-04-2025, 11:26 PM   #19
Flathead Fever
Flathead Fever's Avatar
That car needs to stay original with a flathead; it's a rare car. The very first thing you do with an engine that has set for a long time is to do a compression check on it. You're just wasting your time until you find out that it has compression.
My dad died, and I inherited his '32 roadster. It ran fine when he quit driving it. After 15-plus-years of sitting in his garage I started it, but it ran terrible., it has to stuck open valves. I just need to remove the intake and unstick them, and it will be fine. Also, the gas tank was full of muck. I have it cleaned out, I just need to repaint it. I have 12 car projects so it just sitting until I have the bug to get it running. I had a stroke so I'm not doing much car restoration work right now
If you do a compression test and have a low cylinder, then I'd pull the intake and make sure the valves are all opening and closing. I've seen this twice now, on my dad's '32 with stuck valves and I bought a '51 Mercury out of a car and the only thing wrong with it was one of the lifter keepers had fallen out of it, so the entire lifter and valve were open The guy working on it never tried to diagnose it, he told the guy the motor was no good and sold him a Chevy to put in it. As soon as I got the original standard bore Merc engine home, I pulled the intake and saw the lifter keeper laying in the lifter valley. The guy could have popped it back in and still be driving it. Nice original car and now it's screwed up with a Chevy in it.
Flathead Fever is offline   Reply With Quote
Old 08-05-2025, 05:08 AM   #20
Ggmac
Sending pm
Gary
